05-11-2015, 06:30 AM
Alleged curmudgeon
Putting the travel back in the trailer, questions about tires & running gear...
My nephew bought a dual axle 27' model year 2004 TT in 2007. I pulled it up to the family cottage at the lake for him and he has used it as his small family's weekend getaway and personal sleeping quarters at the lake house for the last 7 summers. The TT has not moved since I parked it there.
When my nephew bought the TT, it had a full set of essentially new Goodyear Marathons on it, which still have only a few hundred miles on them. The tires have been covered the whole time at the lake, and are sitting directly on sandy soil. Now my nephew would like to start camping at campgrounds with us. I am going up there this weekend to take a look at it and see if we can get him rolling safely.
I will inflate the tires and give them an inspection before attempting to pull it anywhere. Are the tires necessarily going to require replacement just because they have sat idle on the ground (although inflated) for essentially 7-8 years? What should I look for in inspecting the tires?
We will also lube the hubs, which I recall are Dexter EZ lube axles. Any advice as to what should I look for there?
I'd appreciate any other running gear inspection hints or suggestions anyone may have to guide our inspections and maintenance as we prep the TT.
Thanks.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
05-11-2015, 06:37 AM
Me being me and knowing how oriented I am towards preventing any issue out on the road if at all possible, and this is just my opinion so others are entitled to give theirs in contradiction to mine by all means, I would replace the tires and pull the hubs down and inspect, clean and repack the bearings, replace the wheel seals, etc...
Just the way i am and the way I have learned to do things. Every time I try and save time or money on the short end I end up costing myself time and money in the long run, not to mention ruining a good time of traveling or camping.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
05-11-2015, 07:02 AM
Alleged curmudgeon
Thanks, Ashley. I appreciate people who are great at repairs and maintenance, but my own abilities are somewhat limited. For now, they are talking about trying one trip out to a state park campground (about 80 miles round trip), just to see if they like it with their two young children. I am hoping to get them rolling with a reasonable effort to make sure things are safe and roadworthy. I am no mechanic, and basic maintenance is about the extent of my competency. Are you saying the Marathons would necessarily be bad after sitting for 7-8 years? It was in very solid working/running condition when we parked it, and the guy who sold it to my nephew was very good at maintenance. As for the work you prescribe behind the tires (pulling the hubs, etc.), do you (or anyone else here) have any idea about what that level of service would cost if we decided to take it in to a dealer? Are you aware of instructionals on those steps to either on FRF or elsewhere on line?
Lee
05-11-2015, 07:32 AM
YouTube is a great source of "HOW TO" for DIY,sure enough you will find lots of usefull videos there.
Good luck !
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
05-11-2015, 07:36 AM
If they are just doing the test run you described then you may fair just fine airing the tires up and pumping some grease in the bearings. You will really want to scrutinize the tires for weather cracking even though they have been covered. I have witnessed a number of times over the years, spare tires that have never been on the road or exposed to direct sunlight separate while hanging in a rack under a vehcile, trailer, etc... I have even had a spare tire I kept inside my car hauler separate simply due to age I guess. It was never outside, never used on the ground, brand new by all rights, just peeled apart. And yes, it was a Goodyear Marathon that was about seven or eight years old.
As far as bearing service, I do all that myself, but believe most shops are gonna hit you for anywhere from an hour to two hours labor for clean and repack or replacing bearings and races. All about the same labor whether repacking or replacing. So, depending on their labor rate it would vary, but the cost would far outweigh having a bearing go out and damage a spindle, hub, etc...
If they decide to do more than the eighty mile test trip, I would still stand by my original post for sure and just replace the tires and service the bearings to have the peace of mind. Again, that is just my opinion though.
05-11-2015, 07:50 AM
Alleged curmudgeon
Thanks, Black, I'll give YouTube a go. And thanks, Ashley. Good advice, for sure. If pulling the hubs on a TT is not much more complicated than on my old Coleman Utah PUP, then maybe I'll even give that a shot, time permitting, before this first trip.
Lee
05-11-2015, 08:08 AM
Vern, really go over those tires. Check for cracks between the treads. Check the sidewalls too. While you're at it, check over the electric brakes and wiring. Made sure the brakes aren't frozen (rusted) up.
As for the bearings, I'd definitely add some grease, don't go crazy or you'll blow out the seals. If it was me, I'd wait to repack the bearings until the TT can sit at the shop for a week or so. Besides, there may be other items in need of repair.
One more suggestion, since it hasn't been moved for a while, I would tow it without the family on board the TV. Instead, have them follow behind in a "chase vehicle" and watch for trouble. After you get some confidence, then they can travel together.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
05-11-2015, 08:20 AM
Alleged curmudgeon
Thanks, RPAspey. Makes sense. I'll go over the tires very closely. We will change them out if we see anything suspicious. I was thinking actually planning on riding with him when he tows it the first time and having his wife and kids follow, so that confirms that for me.
Thinking about the brakes has me wondering about something else. My own TT is in its 4th season now, and gets used regularly and is always plugged in at home, so I'm thinking of things differently with my nephew's situation. Here's another question I've never addressed. Their use for the past 7 years has not involved any concern for the 12V system. If I find the 12V battery on the camper is dead, will the electric brakes still work? (Aside from that potential, they would not really need the 12V for this one outing, since the State park we would stay would have electricity.)
Lee
05-11-2015, 08:27 AM
You should be able to determine the 12v system as far as tail lights, brakes, brake lights, clearance lights as soon as you plug into the tow vehicle. You can and should verify the brakes as soon as you are hitched by manually engaging them and try pulling forward. You should feel the brakes working within less than a foot of travel.
05-11-2015, 08:32 AM
Alleged curmudgeon
Thanks, OC. I understand you to be saying the 12V system can be tested out using the connection to the tow vehicle. Time for a stupid question, though. What you mean by "manually engaging" the brakes is just by using the TV brake pedal, right?
Lee
05-11-2015, 08:46 AM
Most brake controllers, at least mine does, have a manual lever or knob you can move without using your foot on the brake pedal.
05-11-2015, 08:59 AM
I'd charge the battery up and see if it will hold a charge. I know on my old TT if the battery was dead then the fridg, A/C wouldn't work. A lot of items run off the 12v battery including the brake away switch incase the TT comes loose from the towing truck. A cheap 12v battery can be had at Wally World to get them by.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
05-11-2015, 09:00 AM
Alleged curmudgeon
Gotcha, OC. I don't think the ability to do that was really explained to me correctly when my Prodigy (P2) was installed. You caused me to go to Tekonsha's site and watch a video which explained it better than my PDI. Thanks.
Lee
05-11-2015, 09:02 AM
Alleged curmudgeon
Points well-taken, mud yapster. I doubt it will hold a charge and will check. If not, then we'll get that battery replaced for sure.
Lee
05-11-2015, 11:25 AM
Vern, you need the battery to in order to have the emergency brake switch activate the brakes if the trailer separates from the TV.
05-11-2015, 11:53 AM
I'm not an odds maker but being able to make it 10 miles or less without a tire failure with those old tires is a ballpark figure, (IMO).
Airdale
05-11-2015, 07:27 PM
tires
Get rid of the tires. I had 5 yr. old Firestones on my CC. They looked perfect. That is until Discount Tire took them off the
rims. They were cracked inside. They probably have about 12 thousand miles on them and were covered and stored in the trailer barn. Same, same for the bearings. After being parked in the sand for seven years I would not trust that they do not have sand imbedded in the grease. A couple of hundred dollars for a bearing pack is cheap insurance. You might want to try a mobile repair service. Good luck
05-12-2015, 05:22 AM
Alleged curmudgeon
Thanks RPAspey, I imagine we will need a battery, given the age of the present house battery.
Airdale & dwebster - I do think I we will likely replace the tires for piece of mind. However, I don't think they are necessarily going to be bad just from the passage of 7 years. The place it is parked is in the yard (sandy soils with grass), in a location high and dry, and they've been reasonably inflated the whole time (although the inflated tires on have have settled into the soil about two inches over time on one side of the trailer). The wheels, hubs and bearings are up out of the sand and likely not bad, but we will likely pull them and inspect.
Thanks everyone.
Lee
05-12-2015, 10:53 AM
You're welcome. Please report back to tell us how the trip went.
05-12-2015, 11:06 AM
Left Coast
When the wind blows, so does the sand....just say'in
