Old 03-21-2019, 07:38 AM   #1
Mammoth's Avatar
Question about chocks
Hello, I just purchased a rockwood 2509s. I was looking at either the xchock or the onestep. Had anyone used the onestep and know if it will fit? The tires look pretty close together. And if I choose xchock, do I use just one or one on each side?
Mammoth is offline   Reply With Quote
Old 03-21-2019, 07:44 AM   #2
007matman's Avatar
X-chocks are my preference and yes, one per side between the two tires.
Seems more secure having 4 points of contact to the tires (two on each tire).
007matman is offline   Reply With Quote
Old 03-21-2019, 07:44 AM   #3
Mammoth's Avatar
Ok thanks. And would I still use the ramp style chocks under the tires? Or would the xchock take the place of those?
Old 03-21-2019, 07:45 AM   #4
hack522's Avatar
I own the 23SS Roo and only use one. Typically on the side that is adjusted to level. Standard chicks on the opposite side.
hack522 is offline   Reply With Quote
Old 03-21-2019, 07:53 AM   #5
007matman's Avatar
I'm probably being a dork but I have them both so I use them both. I use the ramp style to hold the camper while I'm disconnecting and reconnecting.
Old 03-21-2019, 07:57 AM   #6
KyDan's Avatar
I use one x style chock.
I place it on the right side of my trailer.
It's easy to see so I don't forget to remove it. I ain't crawling under my slide to install or remove one from the other side!
There's no exact correct answer. Do what works for you! Don't sweat the small stuff!
Happy Trails!
Peace!
Dan & Rita D
Old 03-21-2019, 08:00 AM   #7
Always best to use chocks (of any kind) on BOTH sides.
I use the X-chock on both sides. They are the first thing in on arrival (after crawling out of the truck) and last thing removed before pulling out. No need to crawl under any deployed slide.(s)
There was a 13 page discussion on chocks/X-chocks here the last couple weeks.
**THIS** is the thread.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 03-21-2019, 08:03 AM   #8
Mammoth's Avatar
I use the X-chock on both sides. They are first in on arrival and last out. No need to crawl under any deployed slide.(s)
Thanks I'll take a look at that thread
Old 06-17-2019, 10:06 PM   #9
Jayhawker
Jayhawker's Avatar
These wheel chocks would secure your travel trailer! But hauling them around would be a chore.
2018 Surveyor 243RBS
Jayhawker is offline   Reply With Quote
chocks
