Old 01-26-2013, 10:20 PM   #11
Originally Posted by Dave_Monica View Post
I know that you're towing with a half ton. Good to see that you've replaced the P metric tire with LT metric load range E. Thought the max air pressure in the tires is 80 psi, I doubt that the rims will be rated for that, most likely 65 psi. I believe that the max air pressure should be stamped on the backside of the rim.
Dave
Dave, thanks I will check on that in the morning, you know there are so many things to know and so many questions to ask but if don't know what you need to know then how does one come up with the questions to ask???? Dave, Do you know where I am coming from?
Old 01-27-2013, 06:17 AM   #12
Originally Posted by rockwood06 View Post
The question I have is setting the tire pressure on all four tire for a 5 th wheel.
Now when I was towing a TT with a Reese WDS Contol Hitch System I would set the tire pressure on all four tires at max pressure that was listed on the tires and in this case it was 80 psi (load rated "E" 10 ply).
Do I do the same with towing a 5th wheel or just increase the rear tires, now this could be a silly question but my thinking is this, since the Reese WDS contol hitch system places more weight to the front of the tow vehicle I can see the reason of all four tires to be the same , but now with the 5th wheel most of the weight in on the rear how should I do this??? thanks in advance
All 4 tires @ 80psi for me.
Jimtc is offline   Reply With Quote
Old 01-27-2013, 06:49 AM   #13
Herk7769's Avatar
Hard to tell (at least to me) from the Original post if we are talking about the truck or the camper.
Tire pressures are one of the most heavily discussed areas of the forum and many threads exist here about them.
Running max sidewall pressure may be "safe," but overkill and may lead to handling problems when the truck is empty (or not towing) due to tire bounce.
Only knowing what each axles weighs and adjusting the pressures regularly for your actual implementation will you have optimum ride and even tire wear.
As always tire pressure per axle should always be the same. If an axle's weight bearing shows that one tire on that axle is supporting a weight requiring 75 PSI and the other tire on that axles has a load requiring 65 PSI, then both tires must have 75 PSI.
For trucks, if the front axle needs 65 PS and the rear axle is supporting a load that needs 75, then that is how they should be inflated; regardless of sidewall. You should also never have less than your pillar pressures.
HAM CALLSIGN - KC3FFW
Old 01-27-2013, 08:19 AM   #14
The question I have is setting the tire pressure on all four tire for a 5 th wheel..................d
My above comment pertains to 5er TP which is the OPs question.(?)
Old 04-25-2013, 01:04 AM   #15
Went from a 5th wheel (max pressure) to a 26ft bumper pull-I know that I use max for TT but what about the Ram 3500. Do I use the same as the 5er?
Slugger is offline   Reply With Quote
Old 04-25-2013, 09:09 AM   #16
Fulltime family RVer
The easiest answer is - yeah, just go with max and don't worry about it.
The slightly more debated answer is - go get it weighed and then use the load table from the tire manufacturer for the load on those tires.
Old 04-25-2013, 09:18 AM   #17
When I tow, I go to max pressures on truck & trailer and when using the truck without the trailer or a load I go to 35# front & rear.
Old 04-25-2013, 09:41 AM   #18
Good info&thanks
