Old 06-21-2016, 01:49 PM   #1
PhoneDude 8289's Avatar
Raised my 5th wheel
Changed trucks so I had to raise the 5th. Not a hard job, took me five hours, I did the job alone. The hardest part was breaking loose the old nuts and bolts and torquing the new ones to the 130 ft pound spec, not easy for this 69 yr old. One drum had grease on the outside, next will be pulling all drums, checking bearings, brakes and spindles and installing new grease seals all the way around. Think I'll hand pack the bearings this time (old school) and not use the EZ lube zerks. Wish the weather would cool some.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 07-12-2016, 01:06 AM   #2
Nice work!
Do the spacers sit up against the frame or are they supported only by the horizontal bolts??
DO you have dexter or alko axles?
I have a 2010 with alko (assuming as there were alko booklets with it) and want to lift it as well to put larger tires on....
Enliven is offline   Reply With Quote
Old 07-13-2016, 09:03 PM   #3
Just did this on my 831ress wow what a difference it makes in tire clearance, wasn't a bad job definitely would have been easier with power tools .
Soga65 is offline   Reply With Quote
5th wheel, wheel
