Old 06-25-2013, 12:58 PM   #1
Mega Member
Rear Dual Tire Extension Issue
I want to replace a vale extension on the Outside rear dual tire on my 2004 3100 Sunseeker. Rather than deal with jacks, etc. I was wondering if there would be a problem driving that one inside tire up on a leveler, leaving the outside tire raised and able to be removed to get the extension properly seated and tightened. Would this cause undo strain to the chasie? Seems if you can drive the unit for a short while to get a tire replaced (a recent post I read here), you should be able to do this...but....I want the wisdom of others and experience. Thanks!
rgarner is offline   Reply With Quote
Old 06-25-2013, 03:50 PM   #2
Old Enough to Know Better
gasman6674's Avatar
Dont do it. Once you remove the lug nuts both inner and outer will be loose. you could bend a rim, lose a finger etc. Please jack it up properly.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is online now   Reply With Quote
