Old 04-07-2014, 08:26 PM   #1
genecusano's Avatar
Rear End
I'm sure this has been answered before. I have a 2011 half ton Silverado with camper package. 4.8 v8 323 gear, towing 5000lb TT. It does OK with no wind. I was heading south in TX into a head wind. It is a 4 speed automatic tran. I had to run in 2nd gear 50mph 3000rpm. My question is, can I change rear end gear and how would that affect everything else.
Gene & Betty
2011 Silverado
2013 Flagstaff Micro Lite 21 FBRS
Mission, TX
2013-100..2014-180..2015-175..0
genecusano is offline   Reply With Quote
Old 04-07-2014, 08:32 PM   #2
davel1971's Avatar
camper package and those specs? Doesn't sound right. I'm sure there is no way you were in 2nd gear running 50 at only 3000 rpm. 3rd gear maybe. A 4.8 with that gear ratio sure isn't going to be a powerhouse, especially in the wind.
David & Lynn
Old 04-07-2014, 08:35 PM   #3
davel1971's Avatar
oh, can you change the gear ratio. Of course you can. It will make a difference for sure. You will still notice a difference in the wind. Even the strongest of tow vehicles suffer somewhat in the wind
David & Lynn
Old 04-07-2014, 08:37 PM   #4
Oklahoma Proud
MillerTime's Avatar
Usually the ls trucks with the 4.8 don't have tranny coolers, and most don't have reciever hitches and trailer plugs, so if yours has all that your lucky.
Yes the gear change would help you greatly. A 3.73 or maybe a 4.10- if you tow alot. But if wanting factory gears this may set you back $1500+ per differential. The 3.23s you have just dont keep the truck up in the rpms to keep it in the power band.
I have a set of OE 4.10 gears in a tahoe diff. I could get rid of if your ever in the central ok area.
Best of luck!
MillerTime- Future Sabre Handler!!
Old 04-07-2014, 08:37 PM   #5
For the few times you run into a head wind, I doubt it would be worth the time, money and effort. I have a 05 Silverado with a 5.3 and the 3.23 gears and a 5er and just use 3rd gear at 2400 rpm at 55-60mph. If it goes over 60, it will shift into 4th and drop to 1800 rpm. Slight hills will immediately cause it to downshift to 3rd, but maintain 55-60 which is plenty fast enough for me. Trailer tires are only good for 65 anyway. Going in the mountains, I limit it to 3500 rpm regardless of the speed.
Old 04-07-2014, 08:38 PM   #6
Oklahoma Proud
MillerTime's Avatar
Oh and lower gears may help your mpg while towing, but will hurt it when not.
Old 04-07-2014, 08:43 PM   #7
davel1971's Avatar
the negative effects while not towing due to a gear change will be minimal compared to the gain while towing. It all depends on how much you tow and how much this issue bothers you.
David & Lynn
Old 04-07-2014, 09:00 PM   #8
Oklahoma Proud
MillerTime's Avatar
Yep
Old 04-07-2014, 09:15 PM   #9
ironj's Avatar
texas winds cannot be bested....be it with new gears or a diesel...lol but really.... :-(
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 04-07-2014, 09:31 PM   #10
IMO, not worth the time, effort or money for what you gain towing and loose not towing.
