05-22-2017, 08:12 AM
Rear End Always Hitting Road
Any minor dips or uneven road the rear of the unit bottoms out. I believe it is the trailer hitch hitting which seems like something is wrong. I have approx 70psi in the shocks or air bags. Is there something i am missing. It is really getting to be an issue with it dragging because when i put the golf cart on the trailer it is even worse. Any ideas please?
05-22-2017, 08:25 AM
Fonzie
05-22-2017, 08:37 AM
I tow a car trailer with a WD hitch and only drag sometimes in the Carolinas. A lot depends on trailer size and how the weight is loaded on the trailer. I put most weight over the axles, not forward towards the hitch. I also use 100 lbs in my bags and don't haul a full FW tank.
05-22-2017, 08:46 AM
It would be helpful to have pictures of you rig hooked up (TV & TT plus a close up on your WDH). If the hitch is hitting you should be able to see the marks on the bottom to confirm.
I am guessing that you have too much weight on the hitch & not enough distributed forward to the front wheels. Could also be loading too much in front of the tires on your TT.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
05-22-2017, 08:50 AM
He is in a class c.
05-22-2017, 09:11 AM
Also, mine has small skids hanging down just lower then the hitch. Does yours?
05-22-2017, 09:15 AM
Originally Posted by A32Deuce
He is in a class c.
Oh !
I should have caught that with his name (sunseaker 3170ds).
Thanks.
05-22-2017, 09:59 AM
Its funny. I just looked to see where are from. I'm in Charlotte a lot for the Good-Guy car show. Also go to Myrtle Beach for a show every year. Those are the two states where I have a scraping problem. Its how they pave roads down there, high crown and water drain-off.
05-22-2017, 01:54 PM
Are you towing or is this just a classC hung too close to the ground?
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
05-22-2017, 08:12 PM
We had this problem with our Forester 3051S. Was an annoyance for a while, then we hung while trying to get onto a busy highway-the last straw! We changed the trailer hitch from the expensive adjustable one to a $25 one that doesn't extend so far down. We occasionally slightly scrape.
We also have been running about 75 psi in the air bags. Think we'll try using a much higher amount as suggested above.
05-24-2017, 01:32 PM
That "long" leg of the hitch can be cut back after you get the hitch adjusted to the correct hitch hole. Just need a good band saw, I always trim what I don't need.
07-05-2017, 01:45 PM
My Dealer suggested a 2" lift kit for the rear and longer shocks for my 3011 Forrester. did not do the mod traded the class C for a Class A Georgetown no more dragging the rear end.
