05-09-2017, 06:55 AM
Senior Senior Member
Rear power stabilizer not retracting
Trying for an early start from our Wyoming campground. Front stabilizers retracted just fine. Rear stabilizers do not respond to switch. No click no nothing. Oddly the switch will work in the extend position.
I may have to resort to using the manual crank.
Do I need to disconnect the electric motor first?
Any ideas appreciated. TIA.
2015 Flagstaff Super V 26VFKSS Emerald... SOLD
Now camping with a new SOB Winnebago pulled by a 2021 Ford Ranger.
05-09-2017, 06:59 AM
What is your rig? Is there by chance excess load on them? Say from raising tongue jack before raising rear stabs? You ask, hmmm, why would he ask this? Experience. LOL. Been there done that. Trying lowering your tongue jack until the rear stab feet are off the ground. See if that helps.
John
2016 Wildwood 27RKSS
2016 Ford F-350 SRW LB 6.7L Crew Cab
2016 nights camped - 41
2017 nights camped - 3
05-09-2017, 07:11 AM
Got them up
Well, I found the crank and tried out a spin and found the jacks retracted quite easily. The switch works in the extend but not the retract. So it may be the switch. Anyway, we are heading out. Not the best way to start a 4 week trip but it could be way worse. I will be lookin for a RV store on the way and will try to get my hands on a replacement switch.
Still would like input if anyone has replaced that switch before. Or has any other ideas.
TIA
05-09-2017, 07:16 AM
we posted at the same time
John
TT is the one in my signature. It occurred to me that it might be an overload situation of some kind. Problem with your suggestion is that I did not unhook from my truck for the overnight and to raise it off the hitch would not be possible with the stabilizers extended. So for now we're back on the road.
I'll look into it this afternoon in Missoula.
Thanks for your reply.
05-09-2017, 10:59 AM
Sure thing. No signature of your that I could see anywhere. Admin must've removed it. Hope things work out for you.
05-09-2017, 11:06 AM
His signature shows just fine.
What are you using to view the forum?
The mobile app doesn't show signatures, you have to hunt for it.
EDIT:
I do notice one of your posts in this thread doesn't have a signature so I'm guessing you are using two different platforms to view FRF.
I also suspect you don't have a signature set up on your mobile platform.
05-09-2017, 12:34 PM
Ret E-9 Anchor-clanker
Both the front landing gear and rear stabilizer switches are easily replaced. Be sure to mark down the wire color and placements.
05-09-2017, 12:44 PM
Yup, had to replace both of mine after about 2 years. Not as easy to find as you might think, but check with any large RV supply dealership and they should have a replacement. I took a quick photo of the wiring before removing the switch and taking it with me. Glad I did because there are a lot of switches with just a little bit different dimensions.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
05-10-2017, 02:02 AM
I had to replace my rear switch after one year which was covered under warranty. Oddly enough, the remote worked but not the hardwired switch. Finding the issue and replacing the switch gave me a good lesson on trailer wiring (DC/fuses/remote add-ons/etc). Since I bought the trailer from away (I live in Maine but purchased in Vermont), FR sent me the replacement switch. Fairly easy to replace. Good luck and have fun camping!
"How I feel when there is no coffee? DEPRESSO"
Chris & Deb
2013 F150 3.5 EB,Wildwood X-Lite 262BH
Campahedu.com
05-10-2017, 07:34 AM
Had similar issues with rear stab jacks on my 2011 Flagstaff. If I did run jacks out then add more weight by raising tounge, the jacks would not retract after lowering the tounge. Solution that worked for me was to start Manuel retraction by a couple of turns, then electric would fully retract the jacks. Seemed strange but the procedure did work, was not looking to manually retraction every time I broke camp. Lots of luck, thiese minor issues can be a pita to resolve!
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
05-10-2017, 07:49 AM
Handyman
I had both of mine replaced under warranty. They worked with the remote, but not the outside switch. The service rep. said that the factory put on switches that were not water tight. Not unusual for the to fail. Replaced with different kind. Worked fine ever since.
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
05-10-2017, 09:30 AM
EDIT:
iPhone app. Sometimes I paste it in. Signature is setup but probably doesn't auto show on replies. No biggie.
