Old 06-26-2012, 01:10 PM   #1
Rear Stab Electrical Problem
First time on site.
Have a new 8280 and the rear jacks wouldnt retract. Used the handle to retract and the next time they powered down ok. Had to use handle to retract again. Now wont work in either direction.Pulled sw. out and have good 12 volts to it. Couldnt find the " inline 6 amp c/b" thats mentioned in manual. Any ideas ?
Thanks in advance.
Allen
bigguyplane is offline   Reply With Quote
Old 06-26-2012, 01:13 PM   #2
TURBS's Avatar
Originally Posted by bigguyplane
First time on site.
Thanks in advance.
Allen
It would be best to start a new thread of your own youll likely get more traffic and better answers
That being said welcome!
Old 06-26-2012, 03:26 PM   #3
Herk7769's Avatar
There should be two wires going to the motor.
The polarity of the motor determines the direction of rotation.
The switch may be bad or have a lose connection.
There should be a fuse in the power center labeled "STAB" or something like that.
There might also be a auto resetting circuit breaker near the switch.
There also might be a bad ground where it attaches to the frame.
Name:	Lower CB Panel.jpg
ID:	15763   Click image for larger version
Name:	Hidden circuit protection rear stabilizers.jpg
ID:	15764   Click image for larger version
Name:	Horst Probe Install 017.jpg
File Type: pdf 0025d-electric-stabilizer-jack-instructions.pdf (38.8 KB, 17 views)
HAM CALLSIGN - KC3FFW
Old 06-26-2012, 05:57 PM   #4
rear stab problems
Thx Lou
No fuse on panel,couldnt find the 10 second reset 6 amp c/b .behind the switch.
I suspected a bad ground,would explain why it worked after driving for a while,but it means pulling down the underside panels to see where they put it.
Allen
Old 06-26-2012, 06:03 PM   #5
Herk7769's Avatar
Originally Posted by bigguyplane View Post
Thx Lou
Allen
My advice is to think of everything you can possibly imagine that would involve taking the panels down and do it all at once.
Even if you are not sure, run pull tapes so if you decide to run 120 volt wires or TV coax or composite/HDMI video you can drag it through using the heavy duty pull tapes.
led pad
