Old 06-02-2014, 09:17 AM   #11
Ford Idaho's Avatar
Originally Posted by RPAspey View Post
Just went thru this last weekend. I made a gravel parking pad and moved tt onto it the first time. Got out to check my parking job and darn near freaked out. Then I realized how hard I turned to get into the spot. Pulled forward and backed up, all was well. BTW, I actually rubbed the inside of the tire on the wheel well!
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well. C-co, 8/158th, AVN.
Dang, you must have had it cranked over hard!!!!
Old 06-02-2014, 09:30 AM   #12
Have any of you noticed the wheel that you pull up onto a leveling block will look a little funny while it is sitting a little higher on the leveling block?
CUthere is offline   Reply With Quote
Old 06-02-2014, 12:02 PM   #13
RPAspey's Avatar
Oh I did. My local township only permits 18' wide driveways. The parking pad is off to the side of the driveway. So, to back in, I have to practically jackknife to swing it into place.
Let me tell you a secret.... (you and 15000 members) ...... before I move it again, I'll have a can of white spray paint handy. I'll paint a "box" around the TT passenger side tires. Then have a helper place dots beside the TT tires every few feet as I pull out. When I return, I just line the tires up with the dots, and back into the "box" perfect placement even alone.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 06-02-2014, 12:11 PM   #14
...Let me tell you a secret.... (you and 15000 members) ...... before I move it again, I'll have a can of white spray paint handy. I'll paint a "box" around the TT passenger side tires. Then have a helper place dots beside the TT tires every few feet as I pull out. When I return, I just line the tires up with the dots, and back into the "box" perfect placement even alone...
I have two 4 x 4 blocks with angles cut on them and have painted around them to mark their place on the drive. When we leave and the oldest wants to use that portion of the drive, he just puts the blocks by the garage and I know where to place them and still allow about a 4' walkway. TOWTA just goes on about her business while I park, unhook, etc.
roo, wheel
