Old 07-23-2016, 08:06 PM   #1
recommendations for replacement tires on Coachman Clipper tent camper
I have a 1997 Coachmen Clipper 1280 tent pop-up with a GVWR of 2460 lbs. The weight certification decal identifies the tires as B78x13C with a cold PSI of 50 lbs.
What options do you recommend for the size and type of replacement tires? I have been using ST 175/80R13 for a number of years usually replacing them every other year.
Dan Harris
harris10@wideopenwest.com
Dan Harris is offline   Reply With Quote
camper, replacement, tent camper, tire, tires
