Old 07-18-2012, 07:11 PM   #1
sor126's Avatar
Reese 16k 5th Wheel Hitch
Hi All,
New to the 5th Wheel this may be normal but on our Reese 16k hitch the jaws when closed have about a half inch gap is that normal?
sor126 is offline   Reply With Quote
Old 07-18-2012, 07:54 PM   #2
TURBS's Avatar
1/2 around pin when locked in jaws ?
If so yes thats normal there has to be some play .
Old 07-18-2012, 07:59 PM   #3
Originally Posted by sor126 View Post
Hi All,
How are you measuring the gap? Front to back, side to side, all around? Sounds a little much. Will check mine tomorrow, I have the same hitch.
Old 07-18-2012, 08:10 PM   #4
sor126's Avatar
If you are at the tailgate and shine a flashlight into the area where the kingpin meets the jaws the jaws at the rear of the bed have a gap. Checked it today with out the 5th wheel connected and it is the same. With 5th wheel connected I am able to push over the safety latch and pull no problems just want to make sure this is right before we make our 2000 mile August trip
Old 07-18-2012, 08:10 PM   #5
sor126's Avatar
Side to Side looking from the back of the truck
Old 07-18-2012, 08:34 PM   #6
If you have a vernier caliper, measure the kingpin and then the latched hitch. If you don't have a vernier, two straight pcs of wood, one on each side of the pin and measure the distance at the front and back, moving the blocks until you get the same measurement at the front & back and that is the dia. of the pin. Then measure the dia of the latched hitch. I seriously doubt you have a 1/2" difference in the measurements. Maybe 1/8" max., but that's just a guess until I measure mine.
Old 07-18-2012, 08:41 PM   #7
sor126's Avatar
just went out and it is 1/4 inch with the rig not hooked up
Old 07-18-2012, 09:01 PM   #8
Will check mine tomorrow and will see if it can be adjusted. Because mine doesn't have any start or stop banging, I can only assume(there's that word again) it is less than 1/4". I had banging on the hitch legs until I made 0.075 thk steel shims for them.
Old 07-18-2012, 09:06 PM   #9
funkyJunk's Avatar
If you are talking about where the two jaws come together around the pin than that is normal. I had the same hitch and there was always a 1/4 inch gap. Always bothered me but was told it was normal and never had a problem.
2013 Palomino Columbus 385BH
2011 Ford F350 DRW 6.7
funkyJunk is offline   Reply With Quote
Old 07-18-2012, 09:09 PM   #10
Did you measure the dia of the hitch hole diameter or the gap between the jaws at the back?
5th wheel
