11-16-2015, 07:42 PM
Reinforcing the frame to to a trailer?
I have a 2015 surveyor 274 bhss. I already know if I do anything to the frame it will not have a warranty on it.
My question, in order to put a hitch on the rear, what part of the frame needs to be reinforced to handle pulling a 12 ft trailer with either snowmobiles on it or motorcycles on it?
When I bought it, the salesman said it just needed to be welded to the frame.
I don't think he has a clue.
11-22-2015, 09:44 PM
good Question
Advice to not even remove spare tire and carrier and replacing same with a bike rack would do the same. I have a V-Nose, but, same thing applies to the frame. One would assume that from what is discussed, the center where the axles are attached would flex and crack, OR, wall, doors, windows etc. would fail.
I'll try to follow and see what comes on this one.
Charles Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2017 Rockwood Windjammer 3029
Almost South of the Border
11-22-2015, 10:03 PM
You made this Easy,(What part of the frame needs reinforced)? The answer is (Front to Back)! I have a 12' Snowmobile trailer,and a Lite weight trailer/Frame! With 2 snowmobiles on a 12' trailer behind your unit is (Death Trap/NUTS/Goofy/Crazy) just like the Salesman! Youroo!!
11-22-2015, 10:05 PM
Where do plan on driving as some states do not allow triple towing?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
I was looking at replacing the substructure with a 2" x 6" 3/16 steel box to raise the trailer 6 inches, I would also put in cross braces to strengthen that section. I am also going to add shocks and longer leafs. I have some concerns about the trailer hitting the truck bed sides. I seen how weak the leaf hanger look already.
My concern is up front where the right angles connect to the 5th wheel hitch connects. I believe there was a previous recall on weak welds upfront on a 5th wheel.
My normal is in rocky mountains National forest and the roads not all paved. My camping is on uneven ground 98% of the time.
11-22-2015, 10:10 PM
Ham KG5LTL.
11-22-2015, 10:13 PM
Trade It
You must really like the floor plan or something else.
That's a major rebuild and not a MOD / so to speak. I'm thinking I under bought now.
Triples are legal in Texas and other states but have length limits. OH! Also only applies to 5th wheels RVs and not conventional.
Charles Myatt
11-22-2015, 10:29 PM
Surveyor is an ultralight trailer, with an ultralight frame.
if you wanted to do what you want and take it where you are saying you want to, you picked the wrong kind of trailer.
the amount of stress and abuse you're talking about, is just asking for bigtime problems for an ultralight.
you should have bought a trailer with a more robust frame. but it would've weighed a lot more.
like a toyhauler.
11-23-2015, 07:06 AM
How is Towing (2) units Triple? Youroo!!
11-23-2015, 07:28 AM
That is what they they call it I don't know why. Maybe because there are 3 pieces.
Ham KG5LTL.
11-23-2015, 07:37 AM
Good luck, you'll need it.
11-23-2015, 08:35 AM
Time to trade for a heavier unit.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
11-23-2015, 01:11 PM
Here's a heavier unit.
It didn't fair so well either.
11-23-2015, 03:55 PM
Hey Yooroo
I forgot this isn't Australia yet with trailer trains. Leave it to Mexico and it would be.
Give me 40 acres and I'll turn this thing around.
Charles Myatt
11-23-2015, 04:28 PM
You want to tow a 12 foot trailer behind a 32 foot ultra light frame on uneven ground????? The most notorious thread around here is one of the ones Turbs posted where a guy towed an 8 foot trailer with a single golf cart behind his (he had a heavier frame than you) and his frame buckeled and cracked.
Good luck and even if you "beef" it up this is not a mod this is a complete frame rebuild and it still isn't guaranteed to work. I'd look into a toy hauler for something like this.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
11-23-2015, 04:42 PM
This ?
Frame pictures a few posts up
11-23-2015, 04:50 PM
Originally Posted by TURBS
Thats the one I remember, I thought the trailer was longer but that look like 5 foot. I remember him bragging about how well it did, then the thread where his frame was jacked came later......
11-23-2015, 10:59 PM
It sounds like I should take the wheels off of the trailer and put it on a goose neck heavy equipment trailer.
I get the message, "don't do it" and get a toy hauler.
Thanks all.
11-24-2015, 11:55 AM
You wouldn't be the first.
11-24-2015, 07:09 PM
Yes that sounds like a plan that I can live with.
I already found a few that were pretty cheap.
