Old 04-15-2015, 07:56 PM   #11
Send a message via Skype™ to stillontheroad
I am the person who commented that I had a seized up motor. The seals on the motor ruptured and the motor filled with water from driving in the rain. It was not repairable so I took it off completely and pulled the wires back up into the shell so that if I wanted to install a motor later I could. I am not sure what lippert meant by "detente" but using the crank works great and I actually get a more stable trailer using the hand crank than I did with the motor (when it worked.. not long)
stillontheroad is offline   Reply With Quote
Old 04-16-2015, 06:41 AM   #12
DKRITTER's Avatar
I think the next trailer I get is going to have manual jacks. I'll add a couple of center ones as well.
Much much simpler and faster.
Over the years I have have had motor and shear pin issues. Plus they are expensive.
DKRITTER is offline   Reply With Quote
Old 04-16-2015, 07:29 AM   #13
Second trip, rear motor locked up. Had to remove motor to use crank.
Terry2608 is offline   Reply With Quote
Old 04-16-2015, 03:29 PM   #14
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Yellowstone Bill View Post
Have Lippert electric stabilizer jacks on my trailer that have failed.
Both jacks? Hmmmmm ....
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is online now   Reply With Quote
Old 04-16-2015, 03:48 PM   #15
If the motor is Not locked up you can use the Socket on the other end of the assy! It will now be (Direct Drive) and turn very (Easy and Fast) in regards to Jack movement! I let a Alligator take my Motor and Gearbox off! Youroo!!
Old 04-16-2015, 03:50 PM   #16
TURBS's Avatar
Alligator was probably on the left mayonnaise, what was you doing over there?
Snapping off pics?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-16-2015, 03:53 PM   #17
New motor and Gearbox w/shipping to Tucson ,AZ. 400.00$ Youroo!!
Old 04-16-2015, 04:01 PM   #18
Was Lippert Saying (Detent)? Unless they are saying that the (Motor/Gearbox Assy) is a Detent thru the Gear Reduction? Youroo!
Old 04-16-2015, 04:02 PM   #19
And Herk and I profited from your mishap. I thank you every time I deploy my axle jacks. Thanks Gary!
Old 04-16-2015, 04:05 PM   #20
Y'stone Bill, my experience was the same as yours. Crank wouldn't turn. Took motor off and cranked worked easily. I think the "detente" is the resistance in the motor that holds the jacks up. I wired mine in the retracted position to be sure. Oddly enough, when I removed the wiring for the rear jack the front quit working but I could easily crank it down.
jacks
