Old 09-06-2015, 06:21 PM   #21
Left Coast
Herk.....when you pulled your axles, did you notice if any of the rubber in the ends looked like it was squeezing out....between axle end and spindle..? Haven't seen a new one for comparison to a used one.
Old 09-06-2015, 06:24 PM   #22
Herk7769's Avatar
Oh yea.
Will get more photos when I finish the install (tires have not come in yet) and do the post mortem on the axles.
HAM CALLSIGN - KC3FFW
Old 09-06-2015, 06:44 PM   #23
PhoneDude 8289's Avatar
I would think the wheel camber would need to be reset on a new set of axels. I think they do that by bending the axel housing some.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-06-2015, 06:47 PM   #24
Left Coast
Had another question...was a heavier axle not an option....different bolt pattern or brakes? I take it 10" brakes are standard, just wondering if the backing plates and hubs are different on a 6000 axle.
Old 09-06-2015, 06:51 PM   #25
Herk7769's Avatar
Would have loved to, but to do a bolt up in my driveway I needed a direct replacement. Upgraded axles would need different mounts welded to the frame I was told.
Old 09-06-2015, 06:52 PM   #26
Herk7769's Avatar
I don't know how they would do that at the factory as they are just bolted as is to the frame and off the line they go.
Old 10-15-2015, 03:07 PM   #27
Just found this thread as we are thinking of going up to 16" wheels on our Windjammer 3025 and am researching what others are doing. We are wondering if there is enough clearance in the wheel wells for the 16's.
On our '99 Airstream, we replaced our axles in the Spring of '11, upgraded the axles to 3500# each axles, for 16" wheels, and went up to 12" brakes, if I recall correctly, and they are 6-lug. We ordered our axles from Elkhart, and I drove there to pick them up to save money on shipping.
Deb
Windjam2 is offline   Reply With Quote
Old 10-15-2015, 06:50 PM   #28
Keep your 15" wheels & replace your Tires with Maxxis! Youroo!!
Old 10-15-2015, 07:11 PM   #29
gashog's Avatar
2X also go with Steel Valve Stems and "D" load rated, pulls so much better.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 11-01-2015, 02:07 PM   #30
Not really true.
When I replaced my 3500 lb axles with 5200 lb axles on my Rockwood, I got the exact specs of the original axle from Al-Ko. I called Dexter with this information and they spec'd out a 5200 lb axle that only required two bolt holes to be re-drilled. Two of the mounting bolts fit the original holes.
BTW shipping charges for the two complete torsion axles with brakes from the Dexter plant in Fremont, IN to the Dayton Freight terminal in Mentor, Oh was $65.
Best mod i ever made on this trailer.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
axle
