Old 03-30-2012, 09:15 AM   #21
JoeyO's Avatar
Send a message via Yahoo to JoeyO
Question -
Is a bottle jack going to reach the frame to lift up the TT? That distance from the ground is almost 20". So it would seem you would need to stack a few boards under it so it would reach. My TT maxes out at 9200lbs, so maybe a 12 Ton Bottle Jack would do it.
As for the Trailer-Aid, will that work with the EZ-Tow Axels so the bad tire is high enough off the ground to remove it? this would seem lighter than carrying around another piece of heavy steel in the fragile storage compartmets too.
Thanks! Joe
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 03-30-2012, 03:43 PM   #22
J_KHawthorne's Avatar
X2 on the bottle jack, good wrench set and torque wrench!!! I also suggest a good jack-stand as these are light and great security... they are also handy if you're on soft ground and need to hold the trailer up temporarily to slide more blocks under the jack!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 26,890; Nights camped; lost count!
J_KHawthorne is offline   Reply With Quote
Old 03-30-2012, 04:43 PM   #23
camping
tentcamper1's Avatar
had a flat with our previous trailer- we stacked the 2x8"s we use for side to side leveling. loosened the lug nuts, pulled onto the boards and changed the tire. worked very well. took about 20 minutes. on longer trips I have an extra tire I put in the truck - just in case.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 03-30-2012, 05:07 PM   #24
Herk7769's Avatar
If you have ever tried to jack a car or trailer with a bottle jack on hot soft asphalt you will know you should put some boards under that jack. The small metal foot print with all that weight will sink right in.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
