Old 03-15-2012, 11:26 AM   #1
Replacing a tire on a trip + tools?
It just occured to me the other day that if we get a flat on our TT while on a trip, all the dealer provides is a spare tire. There's no jack or tire wrench anywhere that I can see, unless it's under the tire cover. What should we get for a jack? I have a couple of spare bottle jacks. Would they work? A couple of scissor type jacks or a floor dolly? Geesh, there's more dang stuff to store somewhere.
What is the recommended procedure for jacking up one side of a trailer on the side of a road? Our TT is only about 4,000 lbs. One jack fore and one aft of the tires? How do you stabilize the opposite side? Or, do you jack up underneath one of the tandem axles just enough to lift the tire off the ground?
myredracer is offline   Reply With Quote
Old 03-15-2012, 12:08 PM   #2
Wanna Be Camper
SaskCampers's Avatar
Use a bottle jack on the frame between the wheels. The trailer will not go anywhere as long as you are attached to the TV. I carry a 20 ton bottle jack but I like equipment I can use for other purposes if need be. You should have a lugnut wrench as well as a torque wrench and proper size socket to set the torque once you have changed the tire.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2013: 16 2014: 5 2015: 3
Old 03-15-2012, 12:13 PM   #3
We've stopped several times to help fellow rv's out who didn't carry a bottle jack. They thought there car jack would work ok-were they on for a surprise
jmswms is offline   Reply With Quote
Old 03-15-2012, 12:21 PM   #4
caper's Avatar
You can use your set of lynx levelers. Just raise the tire that is not flat off the ground the flat tire will go up also.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-15-2012, 12:22 PM   #5
GlacierGus's Avatar
Does anyone use those plastic ramps to drive up with the good tire which raises the flat tire?
GlacierGus is offline   Reply With Quote
Old 03-15-2012, 12:53 PM   #6
also buy a couple of jack stands for safety.
X2 on the torque wrench and a deep socket. Also breaker bar (wrench) to make it easier. Thankfully never had to change tire yet but prepared.
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 03-15-2012, 01:51 PM   #7
Pirate Todd and Wench
Lets you are carrying a lug wrench, torque wrench, jack stands, bottle jack....anything else? lol
I've changed a tire like "caper above post" does before out of desperation years WORKS great! Bust the nuts loose and roll it up...change, snug, roll it down and tighten and your done just be about 5" high by the time you make a ramp with the levelers. Even a screw on your toaster may need tightened to "spec" but if you have a 14" lug wrench and tighten as hard as you can, you'll find it just as tight if not more than the factory recommended torque of 120ft/lbs. Do yourself a big favor and do this in your driveway at home one time for practice.....and check the torque after your done.
Personally, I don't like carrying my garage just to change a tire "weight and space kept to minimum". I can change a tire as fast as the old man on Christmas story, and I've never lost a lug...let alone a wheel! Except in the snow that time when the hubcap flipped over! F#$%! lol
-Todd and Sherri
-2006 F250 Super Duty King ranch Diesel
-2012 Windjammer 3008w
-Equilzer 1200lb hitch
mrtodds is offline   Reply With Quote
Old 03-15-2012, 02:10 PM   #8
buffalohunter's Avatar
The lightest thing to carry is an emergency roadside assistance card. ;>)
I do carry all the other stuff too.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 03-15-2012, 02:37 PM   #9
Getting a flat tire on your TT really sucks. One late Friday afternoon I had two flat tires on my TT on a trip 60 minutes apart from each other. AAA came out the first time and replaced the flat with my spare. The tire pressure was checked on all the tires before he left. So there I was an hour later on the shoulder of a busy freeway with another flat tire. WHAT AM I GOING TO DO NOW. I have NO spare. Tools to fix? Nope. It's also amazing how many business close early on Friday. AAA said I needed a flat bed to haul the camper and are having a hard time finding anyone. What I ended up doing was unhitching the camper and drive up the road 6 miles and found a WalMart. They carried tires. WalMart put a new tire on the rim of the first flat. I also purchased a few tools to have on hand if I should get another flat. It was now dark outside. AAA was nice enough to meet me back at the camper once I had a new tire and put it on the TT. The wife and I made the best out of the remaining weekend at our camping destination. But that being said Saturday morning I drove to a local tire store and got a new tire to have as a spare.
I hope none of you have to go through this. It was a VERY STRESSFULL few hours.
kjoh75 is offline   Reply With Quote
Old 03-15-2012, 03:34 PM   #10
Triguy's Avatar
We have AAA plus RV, which includes services for trailers but we've been lucky and have not used it (yet). I also carry a 6-ton bottle jack (plenty for my Hybrid), a block of wood to go under the jack to keep it from sinking into the soil or warm asphalt, a breaker bar and a torque wrench.
I think its a good idea to practice if you are uncomfortable. You really don't want your first change to be a rushed effort as you are stopped on the freeway somewhere.
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
