Old 06-15-2016, 08:47 AM   #1
Replacing Dexter torflex axel
I have a 21 FBRS Micro-Lite. Right rear tire showing excessive wear after 15000.mi. Dexter is sending me a new axel. Has anyone replaced an axel and if so, what problems should I expect?
olgeezer2 is offline   Reply With Quote
Old 06-17-2016, 11:28 PM   #2
I am in the process of changing out an axle on my 2010 Rockwood right now. It has a GVWR of 8,418#. The old axle was made by AL-KO, which has been acquired by Dexter fairly recently. dexter shipped me an axle with a different part number and a 3,500# rating instead of 4,000# rating, at least according to the packing slip. After numerous calls to both Forest River and Dexter, I am now pretty well convinced that Dexter has shipped the correct replacement axle. They have changed part numbers with the acquisition by Dexter, and the correct load capacity is 4,000#. It was a flat out error on the packing slip. Anyway, check your axle when it comes in.
I should add that the contacts at both Forest River and Dexter seemed to be knowledgeable and professional in trying to determine if I had the correct axle. Forest River has the capability to determine the exact parts used on your specific trailer if you provide them your trailer VIN.
Paul12 is offline   Reply With Quote
