03-25-2014, 07:15 AM
Guest
Replacing original cheap tires
An expected one of ownership expense should be new tires. So after one year, I have a tiny crack in one of my tires. On our past trailer, we switched to Goodyear Marathons. I was very happy with them, but they are pricey. What other brands do you recommend? All replies will be civil, I know this can be a heated subject.
Next time I buy a new trailer, I think I'll just replace the tires when I take delivery.
03-25-2014, 07:44 AM
I replaced my tires before our first trip out camping.
The delivery driver had one blow out on the trip just to get the trailer to us. When I went to get the trailer state inspected I noticed that another tire was low so I had it pulled off only to find out it had also been plugged due to a leak.
When I had the new tires installed I found out that the spare tire was a Goodyear Marathon tire. And when placed next to the OEM China tires they looked exactly the same with the exception of the name on the sidewall.
All of that being said, the secret to any tire delivering any life is owner maintenance of proper care.
I tried my best to stay civil, as you say this can become a heated argument. Even more so than Ford vs. Chevy vs. Dodge vs. Toyota
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
03-25-2014, 08:27 AM
Guest
This is the tire in question. The surface 'ribbing' is what's split. The actual tire surface itself is not. All three other tires seem ok.
03-25-2014, 08:28 AM
Guest
And I have kept the tires covered since ownership. The trailer never sat on the dealer' lot.
03-25-2014, 08:44 AM
Not impressed with Goodyear in regard to being a strong tire. I have towed at highway speeds with them (TP boosted by 10 psi per a Goodyear bulletin) and never had a problem. However, I have changed a few due to sidewall cuts that happen when taking the trailer off-road and sidewalls hitting sharp rocks.
I would say that is expected, but on my Hummers that I take off-road on some extremely serious trails, I have never had a sidewall cut.
But I guess that is expected with trailer tires, they are not designed to do any type of off-roading where there could be sharp rocks.
So, I switched to Yokohama truck tires. But some serious research and calculations are needed prior to doing the switch and it may not be an option for most. And that last sentence will cause a lot of controversy , but I'm not alone in doing this. In fact, many of the off-road trailers shipped from the factory have A/T truck tires.
03-25-2014, 08:48 AM
Always Learning
When I researched tires- it came to either Goodyear Marathons or Maxxis m8008 tires. Ultimately I went with the Maxxis, but I'm sure I would have been happy with the Marathons, too.
03-25-2014, 08:49 AM
First, JohnIII, that kinda looks like a curb rash abrasion maybe. Are you sure you haven't jumped a curb sometime in the past and just noticed the "split"?
As for brands, if you search FRF (and you will not have to search long and hard) you'll see the 3 most popular brands will be GY Marathons (OC's favorite), Maxxis and Power King Towmax. I personally just bought a set of Towmax because my tire guy, whom I've dealt with for 30 years, recommends and uses them on all his personal equipment.
As for RV owner maintenance...your search of the forum will also discover critical things that us owners must consider/remember. Some of those things will be proper sizing, monitor tire age, tire pressures, maximum speed (65 for most tires), RV balance/equal tire weight loading, curb jumping, and trying to prevent very tight maneuvering which put unbelievable stress on the sidewalls.
I'm not a tire specialist and have learned most of this stuff from our friends on this forum.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
03-25-2014, 08:50 AM
Originally Posted by JohnIII
This is the tire in question. The surface 'ribbing' is what's split. The actual tire surface itself is not. All three other tires seem ok. Attachment 48383
That's how my trail express tires started at first, less than one year old. Then three blow outs over the next year. Caught the fourth one just before she blew. Smart decision to seek new ones now. I had maxxis on my first TT. It was only 4500 lbs but I used them 5 years with no issues. I'll be looking for new tired this spring so I'm interested in watching this thread.
Sent from David's RAZR M.
2018 Forester 3011 DS
03-25-2014, 08:56 AM
Camper Less Camping
I've got over 6K miles on our factory Westlake tires...I've been overjoyed how well they have performed and held up for factory tires.
When I make the move to replace them...best price going between Marathon & Maxxis will be my purchase.
2013 Sabre 32RCTS-6 (sold)
03-25-2014, 09:06 AM
Since there are Les Schwab tire centers literally everywhere out west here, the Power King Towmax will be what replaces my factory tires. If I ever have a problem, Les Schwab will take care of me and they seem to always have what I need in stock or can get it in a few hours.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
03-25-2014, 10:23 AM
Hi,
I just replaced my aging Carlisle (load range C) tires with Kenda Loadmasters (load range D) and new wheels on my Flagstaff HW27SC. Does anyone have any opinions on these tires. I could not find too much info on them. Incidentally I purchased them at etrailer, date code indicates they are 3 months old.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
03-25-2014, 10:37 AM
Guest
My tire place prefers Carlisle over the Marathons. I will check out these other brands as well.
03-25-2014, 11:00 AM
daydreaming about camping
This is the brand and tire I prefer.
Greenball Tires - Towmaster
As far as I know they are the only trailer tire that is rated at 75mph at maximum load with standard pressure. I spoke with one of the engineers one time who confirmed they performed all testing with standard inflation and maximum load.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
03-25-2014, 11:06 AM
Guest
I did have good luck with the GY Marathons on our last trailer. Maybe I ought to go that route. Same price as the Carlisles at DT.
03-25-2014, 11:13 AM
Camper Less Camping
I always look for tires that support my camper's GVWR...I like the TM in my size @ 3500lbs/each
03-25-2014, 11:15 AM
agreed. I stepped up to LRD from the LRC that came stock.
03-25-2014, 01:01 PM
What size are your rims? These are European designed trailer tires. The "C" after the size denotes commercial design. Their 205/R14 LRD has a load capacity of 2271# and a Q=99 MPH speed rating.
http://www.tirerack.com/tires/tires....4857&tab=Sizes
Airdale
03-25-2014, 01:11 PM
My last two Surveyors came from the factory with Power King Towmax tires. I had never heard of them and actually thought they might be China bombs, but the first camper went three years and the new one has gone one year now with no tire issues.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
03-25-2014, 05:35 PM
I used Towmaster on my Palomino Popup and they never failed me. I probably towed that little trailer an easy 10,000 miles on those Towmasters. I was using LRC 12 inch bias ply tires and towed that trailer at 65-70mph all the time.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
03-25-2014, 06:07 PM
So the power king towmax are good tires?? If so lucky me my unit came with them.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
