02-06-2019, 12:08 PM
Replacing tires on F-150
I need to replace the tires on my F-150 before towing my 27ft. Rockwood to Florida. It has P275/65 R18 114T as original tires. I sometimes get some sway and wondered if a heavier ply tire would help. Will heavier ply tires make a rougher ride?
02-06-2019, 12:15 PM
Switch to LT tires (instead of P) and you'll be glad you did.
02-06-2019, 12:29 PM
X2. Exactly.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
02-06-2019, 12:46 PM
X3
02-06-2019, 01:38 PM
Grammar Pedant
I went from those exact P tires (size, I mean) to LT275/70R18 ( Falken Wildpeak AT). Love the tires. Great stability, great performance offroad/snow/rain, look great. E-rated, 10 ply tires with a very high load capacity. But ...
They ride a LOT rougher than the P tires, they are much heavier, and I lost 1.5 mpg. If you're towing, get the LT tires. If you're not towing, then stick with P.
I have Rancho RS9000 in the front and new Monroe in the rear (which are a little softer). My truck was never a Cadillac ride that some people boast of with their 1/2 tons. But, with those LT tires and my shocks, it rides like a HD truck. I just test drove a new F350 diesel 4WD. Took it on pavement and dirt roads (farming roads). It was night and day smoother than my F150 ... the whole family felt the difference.
Former RV: 2018 Rockwood Mini Lite 2504S
02-06-2019, 01:47 PM
IF A MEMBER OF FMCA CONTACT THEM TO SAVE A BUNDLE OF DOLLARS. IF NOT JOIN,
CONTACT MICHELIN FOR RECOMMENDATION.
02-06-2019, 01:54 PM
I would upgrade to LT tires. Go with the E load rating and the largest tire that will fit in your wheel wells. The larger tire will change your speedometer a couple MPH but nothing.to be concerned about.
02-06-2019, 02:23 PM
In some states if the tires fall outside the fender wells, you have to have an appropriate mud flap that covers the spray.
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
02-06-2019, 02:35 PM
I agree with the LT tires, but larger diameter tires will raise your gear ratio, so if you have a 3:55 ratio, you'll be closer to 3:40 with the bigger tires, making towing a little (or a lot depending on your present set up) more difficult. Been there, done that, won't again.
2017 F150 XLT 3.5l Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
2000 Honda EX 400, Rad Rover 6 Plus
02-06-2019, 06:03 PM
Highly recommend Michelin LT tires in the grade and load range you need. Have been using them on our tow vehicles for decades. Typically achieve 60K miles or more before replacing.
02-06-2019, 06:31 PM
x2 Michelin tires, good ride. I run 60psi on my f250 6.7, got 65000 out of last set.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
02-06-2019, 06:41 PM
Grammar Pedant
Michelin tires always get good reviews and seem like a really high quality tire. They also all seem to look like your grandfather's tire and appear better suited for an oldsmobuick than an HD truck.
Good luck.
02-06-2019, 06:45 PM
Good luck.
My grandfathers tire? Can you explain what on earth you mean? Looking at purchasing a set. Thanks
02-06-2019, 06:51 PM
They have great traction on wet or snow covered roads. My grandpa tires handle the elements just fine. Great highway tire, which is where you usually tow your rv. Ok get the pop corn out !!!
02-06-2019, 07:03 PM
Grammar Pedant
Yep. That's exactly what I said. Great reviews. High quality tire.
They look like your grandfather's tire. "Look" is the operative word here ... as in appearance, cosmetics, aesthetics. Go look at a Michelin LT tire. Then, go look at a Toyo, BF Goodrich, and other AT type tires. One of those looks like it belongs a big oldsmobuick land cruiser ... one looks like it belongs on a big truck pushing hundreds of HP and Torque.
But, they're great tires. We all have our own cosmetic preferences. I just don't like the tires on a Subaru Legacy to look more aggressive than on my truck. I don't like putting car tires (by looks) on a big truck.
02-06-2019, 07:36 PM
FMCA Michelin Advantage Plan
Agree with texasgasman. I saved $106 per tire using the FMCA Advantage Plan when I replaced the six tires on my Class A.
02-06-2019, 08:40 PM
And they're quiet
And they're quiet. I'd rather have a quiet tire (regardless of looks) than a tire that rumbles or whines.
Larry
02-06-2019, 08:48 PM
I also replaced the oem tires on the f150 10/18 with Michelin LT's. Ford dealership asked how much towing I do, then steered me towards the Michelin's. A stiffer tire so I expect better wear. A little more road noise, but can live with that. Can't speak for sway, as I haven't towed with them yet. Never really had sway trouble before except in high cross winds with the OEM tires, but they wore before their time from towing.
02-06-2019, 08:54 PM
COSTCO currently has Michelins on sale...
When I was pricing tires for my RAM, the amount I saved buying at Costco was greater then the member fee at Costco... free rotation and balance every 6,000 miles, plus free road hazard insurance too
2014 Shamrock 183
02-06-2019, 08:55 PM
Look at Cooper's lt tires. Much better price than Michelin and have a great reputation. Michelin used to have a great reputation, not so much anymore. Now you pay for the name mainly.
