Bags
Before I deal with the Dealer on the air bags, Check the air lines on each side, from the air valve to the bag, make sure the lines are tight, check the valve cores, air the bags to 80psi, and use soap at the connections points, the lines and hardware is not that hard to replace, Now the bags will loose some pressure, Mine leaked down to 75 from 82psi in 10 days. if you do find a bad line, I would replace both sides to a single air line , to air up both bags at the same time. ( one of the items Im going to do in the fall)
Ive got the same RV, yr and model
Happy camping and travels
