Old 03-21-2016, 08:11 PM   #1
Ridgway Sport tires?
I have a 2015 Rockwood 8315 BSS travel trailer. It came with Ridgway Sport tires. Does anyone else have these tires? Does anyone know anything about them? Are they common on Rockwood or other Forest River trailers? I can't seem to find any info on them at all. I do know they are made in China as stated on the sidewall. They are ST225/75R/15 load range C. What I can't find is a speed rating. I'm assuming they are rated at 65 mph, but I'd like to know for sure. The only thing I can find is H178 after the tire size, but my searches didn't tell me anything as to what that means. I'm doubting that it has anything to do with the speed rating, but what does it mean? I'm planning a trip to Montana this summer and was trying to find some reviews on this brand.
Also a tire pressure question. The sidewall says 50 psi. But I remember reading an article in Trailer life by Bob Livingston, and he said that number is the "minimum amount of pressure required to carry the maximum load". And he recommends inflating the tires something like 5 or 10 pounds above what the sidewall says. Has anyone else heard this? What do you do? I've been towing RV's for many years, but this will be my first trip of this magnitude, and I'm just trying make sure I've got all of my ducks in a row, especially with the tires.
2015 Silverado 2500HD 6.0
Ginger & Sammie (our 4 legged kids)
US Navy veteran
Movike is offline   Reply With Quote
Old 03-21-2016, 08:30 PM   #2
I wouldn't worry about them, just take it to your local GY dealer and have GY Marathon LR D put on all 5 wheels. Better to bite the bullet before one of those blow and tear up the trailer or cause an accident.
Old 03-21-2016, 09:35 PM   #3
Airdale's Avatar
Lionshead Specialty Tire & Wheel, LLC. is located in Goshen, IA and provides OEM tires for the RV trailer industry. That includes the newly minted Ridgway Super Sport ST in Radial and Bias ply designs.
They will be hard to find if replacements are needed on the road.
The recommended inflation pressures for your tires is found on the tire placard and in your trailer's owner manual. The tire pressure found on the tire sidewall is the maximum amount needed to get the maximum load capacity from the tire. In the trailer industry it's normally the same value as recommended by the trailer manufacturer.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is online now   Reply With Quote
Old 03-21-2016, 09:47 PM   #4
Movike,are you sure they say "Radial" there website says they are Bias ply? Youroo!!
Old 03-22-2016, 04:10 AM   #5
Youroo, I assume they are radial because of the R in front of the 15 on the tire size. I guess I didn't realize anybody was still using bias ply tires. How would I know if they are radial or bias ply? If the R isn't for radial, could that be the speed rating?
US Navy veteran
Old 03-22-2016, 04:27 AM   #6
Airdale, thanks for finding that, I'll check it out. I was pretty sure I read that the sidewall pressure was the minimum pressure needed. I believe it was in Trailer Life magazine that I read it, but it was some time ago and I couldn't find it in the archives. In fact I was surprised to read during my search for the Ridgway tires that one brand, Carlisle I believe, said that you can increase the speed rating by like 10 miles per hour by inflating the tires to 10 psi over what is shown on the sidewall. That's the first I'd ever heard anything like that, which I thought was odd.
US Navy veteran
Old 03-22-2016, 05:18 AM   #7
acadianbob's Avatar
I have the same brand of tire on my new Forest River trailer. Mine are load range D and have plenty of excess capacity. I'm going to run them and am not concerned about it. Have a TPMS and will just watch them and do visual inspection. Everyone should be doing that anyway regardless of the brand of tire.
You have radial tires.
I'm not planning to over-inflate my tires. Doesn't seem like a good idea to me. Don't need to go 75 mph either. Planning to tow at 60 mph.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-22-2016, 05:53 AM   #8
My trailer came with Ridgway. I have put about 800 miles on them since we picked up the trailer. I have no idea if my trailer was pulled to the dealer on the tires or trailered to the dealer. Looking at the tires when I picked them up seems to suggest the unit must have been trailered to the dealer. Regardless, the tires still look good. Also, I have a bent axle which the dealer has on order so I sure that is putting a little extra wear on the inside of the tire, but I can't tell it.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 03-22-2016, 06:04 AM   #9
AcadianBob, I was wrong about the Carlisle's. It was on the Tire Rack website and it is the Good Year Marathon and the Power King Towmax STR tires that you can increase your speed rating to 75 mph by increasing the cold pressure by up to 10 psi above what is shown on the sidewall.
Like you, I'm leaning on just going with these tires. I will however, probably have them balanced before I go. I don't plan on exceeding 65 mph either. I was actually concerned that with the load range C tires, that my speed rating might be LESS than 65 mph, but I don't believe that's the case. I do have to admit that for the haul across either Kansas, Nebraska, or South Dakota, which ever route we choose, I'm secretly wishing I could bump my speed up to around 70 just to get across there a little quicker. But I'm not as brave as I was 20 or 30 years ago, so I probably won't push it.
US Navy veteran
Old 03-22-2016, 06:16 AM   #10
wmtire's Avatar
The 65 mph for ST tire 'one size fit's all' thinking, is falling by the wayside.
You are going to see many China made ST tires are starting to have a load index/speed rating on them. This is due in most part to the final import tariffs that are being assessed against Chinese tire imports in 2015.
ST designated tires from China were exempted from this tariff, as long as they met certain requirements, and having the load index/speed rating on the sidewall was one of them.
You can read about it here under #6 of the exemptions:
http://enforcement.trade.gov/downloa...nal-061215.pdf
You may also notice that the Chinese made Goodyear Marathon ST tire now has a speed rating of 75 mph, as per the description note on tire racks webpage for tires made in the second half of 2015.
GoodyearÂ*Marathon Radial
And this from Carlisle tire stating the speed rating has changed on many of its ST tires
http://www.carlstargroup.com/about-us/faq
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
sport, tire, tires
