Old 08-05-2015, 03:34 PM   #11
another_newfie's Avatar
Never have, never will on any RV.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 08-05-2015, 04:22 PM   #12
TURBS's Avatar
2 rv's in ten years and have yet to buy a tire.
Guess it must be something else.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-05-2015, 04:25 PM   #13
TURBS's Avatar
Originally Posted by ayotte View Post
I read somewhere that you never rotate radial tires from side to side as it changes the rotation and the steel belts are conformed to going one way.
If you've properly rotated the tires on your car or truck two always go side to side and turn the other way.
TURBS
2011 32bhok Sabre
Old 08-05-2015, 04:26 PM   #14
TURBS's Avatar
http://recstuff.com/rotatingtrailertires.aspx
TURBS
2011 32bhok Sabre
Old 08-05-2015, 04:34 PM   #15
Maybe it's your sparking personality ...
To each their own. I've had 5 RV's in my lifetime as a RV'r and have yet to rotate any tire, never had a flat, never had to replace a tire either. Nor will I start now.
1 Fantastic DW
1 Amazing DD
Old 08-05-2015, 05:10 PM   #16
Guess it must be something else. TURBS
And I doubt if both rvs together have/had 10K total on both of them together.
Old 08-05-2015, 05:22 PM   #17
mud yapster's Avatar
I'm sure if you hardly get to travel with your RV you will not need to rotate the tires before they rot off. We use ours and we have a triple axle and the rear tire definitely wears more than the front one does. so I just rotate the back to front and front to middle and middle to back each rotation.
I also spray my tires with Areospace 303 so they never dry rot.
To each there own.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-05-2015, 05:28 PM   #18
To each there own.
I can understand different wear patterns on a triple axle, but not on a double axle. If I had a triple axle, I would rotate the tires as you do, I would under no circumstance switch side unless I unmounted the tires and turned them on the wheels and then switch sides. Changing direction on a radial tire is, IMO, bad news.
Old 08-05-2015, 05:44 PM   #19
Taranwanderer's Avatar
This was also told to me by a tire guy. Radials break-in or wear in going one direction, then when you move them to the other side of the vehicle, they wear faster now that they're rolling in the opposite direction from how they were broken in. I know car manufacturers will tell you to go side to side, but tire makers will not...😉
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-05-2015, 06:16 PM   #20
Oaklevel's Avatar
If I rotated tires on the camper I would be in the tire shop every other week I am there enough now that we are on a first name basis. I have bought as many as 20 tires in one year, (only bought 8 so far this year) so no I do not rotate the tires on the camper nor do I on the other 2 duel axle trailer I have. The DW says I have a car for every day of the week............
Never had a trailer tire wear or blow out & yes I have a few China bombs.......
I pull 5 different trailers & it is not unusual to be anywhere in the mid Atlantic moving one of the boys esp when they were in college. The box trailer was in Clarksville VA a couple weekends ago moving our niece & in Wilmington NC in April moving #2 son.
The wife's car was bought last Sept and she has put 35K on it so far, I have the truck, a driver Mustang (to go to work) & often (last weekend) help the boys get their tires. I try to rotate the cars tires ever 7-10K but that does not always work. I usually put 30K a year on my car too but this year I may not quite make it.
The long and short of it is in 30 years of owning campers & other duel axle trailers I have never rotated the tires. Mine always time out before they wear out.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
tire, tires
