Old 08-05-2015, 05:53 AM   #1
Rotate Tires on Units!
I rotate my TV tires every (5000 miles)! Same with our TT tires. Members who have OEM ?? Tires sometime (Replace/Remove) more often! Do you Rotate your RV tires? Youroo!!
Old 08-05-2015, 06:24 AM   #2
TURBS's Avatar
I rotated the sabre tires this year.
x them side to side.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-05-2015, 01:58 PM   #3
Airdale's Avatar
Because RV trailer tires are all subjected to the same forces all the time they probably don’t need to be rotated. However, I rotate mine from side to side every 3000-5000 miles to off-set the effects of road crown.
Airdale is offline   Reply With Quote
Old 08-05-2015, 02:02 PM   #4
Never have and probably never will, see no need as has been said, they all see the same use at the same time. IMO, just a waste of my limited energy.
Old 08-05-2015, 02:03 PM   #5
mud yapster's Avatar
If you have a tandem or triple axle they need to be rotated for sure. The. Rear tires scrub side ways when turning and wear.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-05-2015, 02:25 PM   #6
rsdata's Avatar
wouldn't the most loaded axle, front or rear as the case may be scrub less then the lesser loaded?
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-05-2015, 02:40 PM   #7
All 4 tires scrub when turning if you look closely.
Old 08-05-2015, 03:05 PM   #8
dieselguy's Avatar
On a fiver there is no drive nor steer axle, so I see no need to rotate my tires. Both axles optimumally have the same camber and toe-in and yes both axles scrub a bit on turns.
dieselguy is offline   Reply With Quote
Old 08-05-2015, 03:25 PM   #9
Cyber Phrenologist
Radio's Avatar
No, I don't rotate the 5th wheels tires.
The mortal enemy of my tires is dry rot from lack of use, not wear. The sidewalls will have cracks long before any uneven tread wear becomes apparent.
Need more time to camp.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 08-05-2015, 03:32 PM   #10
I read somewhere that you never rotate radial tires from side to side as it changes the rotation and the steel belts are conformed to going one way.
ayotte is offline   Reply With Quote
tire, tires
