Old 10-23-2015, 12:56 PM   #11
Originally Posted by Gyrogearloose View Post
X3 or maybe X4
Shocks aren't the reason the vehicle sags.
The problem is that the springs have weakened or were stressed beyond their elastic limit at some point.
Get new springs.
And if you go to the trouble and cost of replacing the springs, it makes no sense to put old shocks back in.
X2. With a new set of springs, you wouldn't have to get air leveling shocks, but a new set will help the ride.
ottawapaul is offline   Reply With Quote
Old 10-23-2015, 12:57 PM   #12
RSchleder's Avatar
Shocks, with the exception of air shocks or air bags, are not designed to carry the weight of your vehicle. That's what springs or air bags are for. Shocks are there to control the "spring action" of your leaf or coil springs. I'm sure you've seen old vehicles bouncing up and down as they navigate down the road, they need NEW SHOCKS!
The recommendation of new spring and shocks is a solid recommendation. The alternative would be air shocks or air bags to supplement your current rear springs.
Myself, if the OEM suspension is adequate to handle the weight your putting on the rear of your vehicle, I'd replace the springs and shocks. If that weight is at or close to the max weight your vehicle can handle, consider air shocks or air bags.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 10-23-2015, 12:58 PM   #13
TURBS's Avatar
Originally Posted by Kenny kustom View Post
Given the age, I would just have a new set of springs installed.
Add a new pair of shocks too.
2008 F350 CCSB V10
2016 Sabre 36QBOK
I'm totally with this route.
Why put a band aid on it?
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-23-2015, 12:58 PM   #14
As an afterthought, you could have a set of springs custom made for your Burb to carry your weight and avoid the hassles of air shocks.
David and Vicki
6 year old Springer rescues Sydney and Piper
2014 GMC Denali 3500HD Dually Crew Cab Duramax/Allison stock
2016 Dutchmen Denali 287RE "The Dog House"
Eaz Lift WDH 1400# w/ Blue Ox 2 1/2" trunion
EezRV TPMS
Springerdad is offline   Reply With Quote
Old 10-23-2015, 01:28 PM   #15
Kenny kustom's Avatar
Check out deaver springs.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Kenny kustom is online now   Reply With Quote
Old 10-23-2015, 01:42 PM   #16
We used Supersprings Helper springs. They work great but a bit stiffer ride. Auto Anything will match Amazon with free shipping and no tax. Simple install
sailtrkr is offline   Reply With Quote
Old 10-23-2015, 02:00 PM   #17
Originally Posted by youroo View Post
IF you feal safe with all the Weight held up by (2) 1/2" shock rods take their advice! Youroo!!
Shocks don't hold up any weight; they control motion. Exception---coil over shock (race car) or air shocks. Otherwise, they control spring oscillation.
That why they are called "dampers" in some circles. Add a leaf to your springs. Did that to a Dodge van with good results.
pdqparalegal1 is offline   Reply With Quote
Old 10-23-2015, 02:58 PM   #18
My Post was meant as a slam,I know what shocks are for! Youroo!!
Old 10-23-2015, 03:42 PM   #19
We have used Firestone Ride-Rite air bags on our last three trucks. They make a world of difference when towing or carrying heavy loads. These bags are place directly between the axle and the frame. I would suggest these over air shocks because they are much more substantial and last a very long time. The pressure can be adjusted according to the load. We use 10 lbs without a load and 60 lbs when we had a slide in camper. Forty to 50 lbs would be the range for a travel trailer. You can level your rig with air pressure. You can't do that with helper springs.Ride Rites are also pretty easy to install yourself.
PenJoe is offline   Reply With Quote
Old 10-27-2015, 11:19 AM   #20
As a follow up, we just installed NAPA self-adjusting shocks and see/feel the difference. Taking our trailer out this weekend for one last outing, so we'll see how it does. Thanks for all the comments and suggestions.
gfarmcafe is offline   Reply With Quote
tow vehicle
