Old 05-30-2016, 01:51 PM   #1
Question scissor jack maintenance
How often should I lubricate my scissor jacks and with what product?
plmoss is offline   Reply With Quote
Old 06-05-2016, 08:33 PM   #2
Not by the book, but I use automatic transmission fluid (ATF) for situations like this. Grease collects dirt, ATF stays pretty clean. ATF evaporates over time so I relube about once a year.
Fred W
2014 Rockwood A122 a-frame
Old 06-13-2016, 02:31 AM   #3
I use Dri-Slide. Doesn't collect grit and stays put pretty well. It's black so be careful of overspray.
mordecai is offline   Reply With Quote
Old 06-15-2016, 04:34 AM   #4
Rhody's Avatar
Scissors Jacks
I notice I keep getting surface rust on my Scissors Jacks.
I have been using WD 40 but my gut tells me that's not the soloution.
Should I sand an spray with Rustolium before I think of Lube??
Rhody
Rhody is offline   Reply With Quote
Old 06-15-2016, 04:38 AM   #5
Cut_un's Avatar
X2on the dry lube
Cut_un is offline   Reply With Quote
Old 06-15-2016, 04:42 AM   #6
Rhody's Avatar
Originally Posted by Cut_un View Post
X2on the dry lube
Ok I am sorry...X2? Dry Lube?
I'm a rookie
Guess I need to Google!
Thank you!
Old 06-15-2016, 05:07 AM   #7
Rhody's Avatar
X2on the dry lube
Is it called Just X2?
Old 06-15-2016, 05:11 AM   #8
Cut_un's Avatar
No... I was just agreeing with the above posting! Got mine from the RV dealer but I'm sure you can get it from most any automotive parts store!
Old 06-15-2016, 05:17 AM   #9
Rhody's Avatar
Ok so at the risk of sounding like a dumbass....
This stuff is called X2 Dry Lube? <Correct?
Thanks,
Rhody
Old 06-15-2016, 05:54 AM   #10
Canadian Member
itat's Avatar
No. The "X2" is used here on the forum to mean "times 2" or "I agree with that statement".
For the scissor jacks, I use a dry graphite spray lubricant like this
Graphite Extreme lubricant | Jig-A-Loo
I use it a couple times a year but if you use your RV more frequently you could use the lube more frequently.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
maintenance
