Old 09-09-2016, 09:50 AM   #1
Self adjusting brakes
As a proud owner of a2016 2504s, we have put about 4000 miles on it so far this year. Getting ready to lube the axles for the first time. My question is do I have self adjusting brakes? Is there a way to tell without pulling the drum? I looked through all the paperwork that came with the unit, there is nothing for either the axles or brakes. Thanks in advance for any input. Jay
Jay2504 is offline   Reply With Quote
Old 09-09-2016, 12:14 PM   #2
raspivey's Avatar
Most likely. My 2014 did and so does my 2017. You can look on Forest River's website and look up the Rockwood sales people. I emailed them a few questions while mine was on order and got a response within a few hours. They can probably tell you exactly what is on it.
2012 Chevy Tahoe LTZ - HD tow package
Old 09-09-2016, 01:46 PM   #3
Thanks. While under the camper reworking the battery cables ans doing a inverter pre-wire I read a sticker on each axle that said "never adjust". I assume that that means self adjusting brakes. The other sticker on each axle said: "3000 LB". That must be the weight rating of the axle. Anyone know how these self adjusters work? In a car it's either by backing up and braking hard or using the emergency brake. Jay
Old 09-09-2016, 05:00 PM   #4
Head Rambler
Those self-adjusters work basically like the old automobile ones. They adjust mostly when backing up.
It's still a good idea to manually adjust them about once every year or two to be sure they stay properly adjusted.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-09-2016, 06:58 PM   #5
raspivey's Avatar
That's what I've done. I'll manually set them if it feels like I need to bump my controller gain up from where it normally sits. It took just over two years for me to do it on the last trailer and I probably didn't really need to do it then.
Old 09-09-2016, 07:01 PM   #6
Members
Tommy Joann's Avatar
The never adjust brakes work on forward momentum.
2015 Flagstaff 8528CKWSA Diamond Package
2015 Chevy Silverado Crew Cab LT
Husky 16K W Hitch w/ Husky 10-16 Composite Glider
Reese Revolution Pin Box
Tommy Joann is offline   Reply With Quote
Old 09-09-2016, 08:28 PM   #7
Head Rambler
I'm in no way doubting you, but where did you get that info. Is it in any of the manuals?
It's good info to know.
Gotta go campin!
Old 09-09-2016, 09:31 PM   #8
VinceU's Avatar
Google "never adjust brake", tons of sites describe ops.
Old 09-09-2016, 09:37 PM   #9
I sure hope that they adjust going forward. I have memorys of backing up a drum brake car fast in reverse then pumping the brakes to make them adjust! I would not like to try that with my TT! I haven't noticed any decrease in brake performance, but might adjust them up a little manually anyway. I have tried that with cars with auto adjusters and it works for a short time. Jay
Old 09-09-2016, 09:41 PM   #10
Members
Got it from Dexter's you tube video.
brakes
