Old 08-26-2014, 07:52 PM   #1
self adjusting brakes
had one wheel hot and three normal, for the second time found the brakes adjusted too tight on this hub, so being a long way from home I just removed spring from self adjuster and temp solved this problem. anyone else had a problem with there lippert self adjusters??
rr retired is offline   Reply With Quote
Old 09-16-2014, 05:23 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Mine would not even adjust. Had to have the mechanic do it.
donanddona is offline   Reply With Quote
Old 09-28-2014, 09:41 PM   #3
dean178's Avatar
Yeah, I had just said in another post about hitting a gator and it setting off my brakes and one of the self adjusters came apart. I did away with that kind of braking and one of the techs at Lippert told me that the none self adjusting ones are better. I got my replacement brakes from Texas Trailer Parts I think it was called but Etrailer has them also. they have a little bigger/thicker magnet and that is why he said they are better.
Dean.
2012 Surveyor Select sv303.
home on the road for Susie & I and our 4 dogs.
pulled by a 08 Dodge 6.7
dean178 is offline   Reply With Quote
Old 10-25-2014, 09:02 PM   #4
Jr. member & newbie
I had the same problem on a 18 month old Cherokee we bought new.
After removing the wheel and backing off the brakes twice, I discovered that the cable that activates mine was twisted and thus slightly shorter (and I guess more aggressive on the adjustment). I untwisted it and haven't had any more problems.
2014 Cherokee 264L, 2013 Tundra DC - Flex, 4wd, tow pkg, TRD pkg, Prodigy 2, 10K Equal-izer,
hagar is offline   Reply With Quote
Old 12-06-2014, 10:20 PM   #5
my experience with self adj dexter was 3 wheels didn't adj and 1 dropped out the adj wheel and ground up in the drum maybe the 2nd year will be better
Big Bill is online now   Reply With Quote
brakes
