Old 11-19-2015, 12:15 PM   #11
Head Rambler
It's a dampener that's on the front of the crankshaft. It has a rubber bushing built into it and I've seen them sling out and the ring get one sided and cause a vibration. It also has the belt pulley built into it.
Gotta go campin!
Old 11-19-2015, 12:36 PM   #12
Kenny kustom's Avatar
Harmonic balancer would be more rpm dependant.
His, is speed dependant, so more like to be driveline.
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-19-2015, 01:06 PM   #13
1fotonut's Avatar
duh....I should have known what harmonic balancer was....no...it does not vibrate when revving engine...front drive shaft meaning from section in front of carrier bearing..I would think it would have been checked. I will ask these questions tomorrow when I am there. I greatly appreciate everybody's responses. This had been a very frustrating. This unit only has 21,000 miles on it. We've used it very little in two years (1,000miles)because of this problem.
Ron & Mary Lutz
Hagerstown, MD
1fotonut is offline   Reply With Quote
Old 11-19-2015, 01:19 PM   #14
1fotonut's Avatar
My motorhome is at
D & D Truck Repair & Towing, Inc
16803 D Notley Road
Hagerstown, MD 21740
Fleetcare/Freetpride Affiliate Since:
5/20/2008
Services
Fleetpride
AC
Brakes
Drivetrain
Federal Inspections
Fleet Maintenance
Heavy Duty Engine
Heavy Duty Suspension
Hydraulic Hose
Preventive Maintenance
PTO
Steering & Alignment
Tank Repair
Trailer Body Repair
Ron & Mary Lutz
Hagerstown, MD
Old 11-19-2015, 01:33 PM   #15
B and B's Avatar
Originally Posted by Kenny kustom View Post
Usually seat vibe is coming from the driveline, rear end.
I'm with turbs, carrier bearing on the two piece rear shaft.
Explain the " front driveshaft "
As your rig is rear wheel drive.
2016 Sabre 36QBOK
x3. I replaced a couple on my Econoline E250s..
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 11-19-2015, 02:33 PM   #16
rsscully's Avatar
Originally Posted by 1fotonut View Post
My motorhome is at
16803 D Notley Road
Over near the valley mall?
rsscully is offline   Reply With Quote
Old 11-19-2015, 02:35 PM   #17
Why or what are you meaning when you say " retube" the driveshaft?
What was the reason?
Did you damage it?
Is it out of balance?
Biggest question...
IS IT OUT OF PHASE?
You said it got worse, after they messed with it.
My advice, take it to another shop, tell them to install new driveshaft.
That one has been ruined, most likely.
2016 Sabre 36QBOK
Old 11-19-2015, 03:40 PM   #18
1fotonut's Avatar
as I understand...retube means replace the steel tubing between the end fittings because it was slightly bent....then balance. This assembly has a front and rear shafts with a carrier bearing in the middle. My understanding is they sent the entire assembly to a facility that was able to balance the entire assembly...but the vibration is even worse..I am invested at this repair facility because I have given them $2500 so far. So I'm trying to make then fix it so I can make good on my $2500 invested.
Ron & Mary Lutz
Hagerstown, MD
Old 11-19-2015, 03:47 PM   #19
1fotonut's Avatar
At this point if can find a solution through the experiences and (help)abilities of others, maybe I can help them find the problem. So, all suggestions/solutions are greatly appreciated.
Ron & Mary Lutz
Hagerstown, MD
Old 11-19-2015, 03:53 PM   #20
I wonder what you hit to bend the driveshaft.
I still feel the issue is with the shaft,
As you say, it got worse after they " fixed" it.
2016 Sabre 36QBOK
