Old 11-19-2015, 05:23 PM   #21
1fotonut's Avatar
I didn't hit anything...it had to be that way when I bought it.
Ron & Mary Lutz
Hagerstown, MD
1fotonut is offline   Reply With Quote
Old 11-19-2015, 05:53 PM   #22
A32Deuce's Avatar
My SunSeeker has three driven shafts with two carriers. Two is a lot to get out of balance.
A32Deuce is offline   Reply With Quote
Old 11-19-2015, 06:20 PM   #23
1fotonut's Avatar
About the bent driveshaft...when I had the tires replaced the small shop where I had it done...the owner had his 19 yr old son helping. I had it back a couple times and they tried rebalancing and checking wheels. Then decided to replace all the tires with different tires if we paid the difference... I know they used a large floor jack and jacked the rear axle from the differential...The vibration was worse after they replaced all the tires the 2nd time...to this day I wonder if the son may have missed the differential and jacked on the driveshaft....because I wasn't there when they put the replacement tires on. Does that make any sense.
Ron & Mary Lutz
Hagerstown, MD
Old 11-19-2015, 06:31 PM   #24
Kenny kustom's Avatar
What you are explaining makes sense.
Although, that would be difficult to do, with the design of the axle.
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-19-2015, 06:34 PM   #25
I understand, wanting to stay with that repair shop, but it might be worth a shot, giving to someone else to have a look.
Just diagnose. No repairs.
Shouldn't be more than an hour.
Just to get a second opinion.
We can say all we want, but without looking at it, it all just a guess.
2016 Sabre 36QBOK
Old 11-20-2015, 07:55 AM   #26
A32Deuce's Avatar
Jacking up by the rear is a no no! That is why the jack under the spring perch. Doesn't take much off-balance to bend the housing! More than likely had been done earlier and this time compounded the problem. Ask a good small truck repair shop, they will tell you not to do it.
Old 11-20-2015, 08:20 AM   #27
Head Rambler
If the entire shaft assembly was sent and balanced then surely they would have found if it was bent or dented. I've re-tubed a couple of drive shafts over the years and bends and dents are very obvious when trying to balance a unit. I can also tell you that a carrier bearing can appear to be good upon first look, but indeed be bad.
I'd give them a list of the suggestions you've gotten here and let them go through them and assure you that they've checked all of them.
Gotta go campin!
