Old 12-24-2014, 04:04 PM   #11
Thanks Paul M
So I take it the self tapping bolts stay tight. They don't loosen or wallow out the holes. If so sounds like a fairly simple install. I don't have the patience or the mobility I once had due to old father time.
Papa GLS is offline   Reply With Quote
Old 12-24-2014, 04:18 PM   #12
Papa GLS, The bolts are 1/2 inch if my memory serves right. There are four per bracket, I have not seen any signs of failure. Some other post I was looking at when trying to make my choice said the shocks themselves were not the best, but when that time comes I will pick up some new ones locally. It's not like it's on the road every day.
The bolts may be 3/8. The trailer is back at the factory now, otherwise I could take pick for you.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 12-25-2014, 08:28 PM   #13
I had my buddy make up lower brackets I designed.I added a 3"riser to lift the trailer and to have a place to weld on fabricated upper brackets.The lower brakets were drilled and tapped for bolts that were put through from the brake shoe side of the brake backing plate.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 12-25-2014, 09:44 PM   #14
Swift2
Swift 2's Avatar
I just ordered 2 kits from CW and will get to put them on in a week or so. The kits look pretty complete but only time will tell. My last trailer (Fleetwood) came from the factory with them 10 yrs ago.
Swift 2 is offline   Reply With Quote
Old 12-26-2014, 09:01 AM   #15
Swift - Let us know if you need to make any mods for the slide out mech.
"Paul & Laurie"
Old 12-29-2014, 06:04 PM   #16
Swift2
Swift 2's Avatar
Will do on the slide out question. I'll be picking the 320RS on Tue. Then off to work on it. Any help on the angle that the shocks should be mounted at. Some seem to be mounted straight up and down and some are at angle. She has 2 axels and our Fleetwood shocks were mounted at an angle. Any help out there?
Old 12-29-2014, 06:43 PM   #17
Main thing is to try to get the shock mounted as close to 90 degrees to the torsion arm when it is in the loaded position. This was not possible on the driver's side on our trailer because of the slide mechanism.
Old 12-29-2014, 09:13 PM   #18
LKicklight's Avatar
SHOCKS
We currently own a 2011 Crusader 270RET by Prime Time. After our extensive travel to Alaska, noticed the tires wearing funny, was told by another RV old timer that this is caused by not having shocks on the axles. Have checked locally and have been told it is not a big deal to install a set. Anyone else have this mod on there mines as well...
kickster
2500HD 6.0 Gas/Ext. Cab
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 12-29-2014, 10:09 PM   #19
Swift2
Swift 2's Avatar
Thanks OldCoot. I'll get to it this next week. Got to get the trailer back from CW Mon or Tue.
Old 12-29-2014, 10:33 PM   #20
TURBS's Avatar
Old coot has done this to his 5th wheel.
