Old 12-30-2014, 05:02 AM   #21
AquaMan's Avatar
SHOCKS
I installed a set on mine last year. Was fairly simple work. I don't think it gives me quite the smooth ride as OC claims, but I'm a good bit heavier than he is.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-30-2014, 05:31 AM   #22
If you have the Lippert kit, the brackets that mount on the shackles are bent to put shock at an angle.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 01-08-2015, 01:31 AM   #23
paul M is saying true about that
zirarzirar is offline   Reply With Quote
Old 01-08-2015, 08:40 PM   #24
Swift2
Swift 2's Avatar
I got my shocks from CW and got them installed yesterday. The kit was missing a few bolts other than that it was good kit. Easy to install. Took me about 6hrs. I did have to weld a 1 & 3/4" extension on two of the upper brackets (one on each side) to get around the square shaft for the slideout. I haven't had a chance to try it out yet.
Swift 2 is offline   Reply With Quote
Old 01-08-2015, 09:16 PM   #25
Brother Les's Avatar
The latest flyer that I received from Camping World has the shock set called 'Joy Rider' for 259.99. Is that what you put on and does that come with four shocks (two for each side)?
Brother Les
