Old 12-23-2014, 07:57 PM   #1
Shocks
I know this has probably been addressed before, but I haven't seen anything about it, so I thought I would ask. Has anyone ever considered or tried shock absorbers on a TT? If so, what were the benefits if any. Seems to me they would eliminate a lot of the bounce. Thanks for any info.
Papa GLS is offline   Reply With Quote
Old 12-23-2014, 08:01 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
OK Old Coot where are ya? Try the search menu. OC has done this too.
donanddona is offline   Reply With Quote
Old 12-23-2014, 08:08 PM   #3
donanddona's Avatar
Forest River Forums - OldCoot's Album: Adding shock absorbers to Alko torsion axles
Old 12-23-2014, 08:17 PM   #4
Thanks for info donanddona. So it has been done. I'll wait for info from Old Coot.
Old 12-23-2014, 09:00 PM   #5
Just Love to Camp
TheFordes's Avatar
Might want to pm OC
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 12-24-2014, 10:18 AM   #6
I also put shocks on our trailer. The bounce that the trailer had is gone and it rides smoother. I raised the trailer 3" for the clearance we need to get into some of the areas we go in the boonies as well as to be able to get on and off some of the inland ferries the we go on as well as a place to weld the upper shock mounts on.
Forest River Forums - 09grizzly1's Album: 09grizzly1's Shock Install
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 12-24-2014, 10:42 AM   #7
I installed shocks on our 2013 Columbus 5th wheel. Rides better and helps with reducing chucking. I did it after reading OC's suggestions. Glad I did it.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 12-24-2014, 12:11 PM   #8
Thanks 09grizzly1 & Paul M
Did it require any welding or is there a bolt on kit available? If so, where.
Thanks again for the info; I appreciate it.
Old 12-24-2014, 03:39 PM   #9
Looking online & found a bolt on kit from Lippert. Has anyone tried this & if so how did it work. A little leery of how the top bracket mounts. Doesn't use bolts, but self tapping screws like the ones used on sway control trailer tongue bracket.
Thanks again for any info.
Old 12-24-2014, 03:56 PM   #10
Lippert makes a kit. I did have to weld on a short piece to extend the shock to clear the square tube that operates the slide. Not a big deal unless you don't have a welder, but nothing a local shop could not handle. The self tapping screws are more like bolts. You need to drill a pilot hole. I use some thread cutting oil and an impact gun. Worked well.
"Paul & Laurie"
