Old 07-10-2014, 09:04 PM   #31
Originally Posted by amxpress View Post
Good luck with your new GY tires. But they're not called China bombs without good reason.
Next time you need tires, go with either Maxxis or Kumho ST tires. They're the only ST tires not made in China. Be sure to have your new tires balanced and install steel valve stems.
Don't get your hopes up, they are all made just down the road from China. All ST tires are made in Asia.
Old 07-10-2014, 10:07 PM   #32
amxpress's Avatar
Yes, but not all ST tires are created equal. BIG difference.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 07-10-2014, 11:01 PM   #33
Don't think anyone implied that they were. Nor are all Chinese made tires junk, depends on the manufacturer. What makes the difference if they are made in Taiwan or China as long as the mfgr has control like GY vs Maxis?
Old 07-10-2014, 11:31 PM   #34
Where should we go next!
Offagain's Avatar
It's sounds like some have had good luck with the Marathons. Maybe it was just a fluke that I lost both of mine.
It very well could be that I did run something over. I didn't see any debris on the road, but you never know.
I believe Walmart sells trailer tires and wheels already mounted and balanced. I'm going to purchase one and put it in the campers storage. I'd feel better with two spares.
Ford F-150 4X4 Supercrew Ecoboost
Surveyor SV291
Equalizer 4-point 10K lbs.
Offagain is offline   Reply With Quote
Old 07-11-2014, 12:40 AM   #35
sail2liv's Avatar
Did the tires exceed 60 mph.....under normal towing? Do you think a TPMS would have alerted you before ?
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 07-11-2014, 06:40 AM   #36
Offagain's Avatar
I do not have a TPMS system on this camper. Didn't know you could purchase one. Either way I always check tire pressure and did so right before heading out.
I do not exceed 60-65 mph when towing. Usually the cruise is locked in right at 62mph. Steady as she goes and I'll get there when I get there.
Surveyor SV291
Old 07-11-2014, 06:54 AM   #37
Devilscreekw's Avatar
Originally Posted by rockfordroo View Post
So if my math is right, you sold a trailer with 19 year old tires on it?
Wow. Rule of thumb is no more than 7 years. You almost tripled that.
Yes, I am embarrassed to admit that...but I told them how old they were..
Now, the trailer was stored indoors continuously, on a cement floor. If it wasn't being used, it was inside.
No sign of sidewall cracks, and lots of tread left.
Now on my horse trailer, it's a continual rotation. There always seems to be one that needs replacing. I think I have every make discussed on it somewhere. With 3 horses inside it is over 8000 lbs.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 07-11-2014, 07:05 AM   #38
Incheon, S. Korea
BigBaron's Avatar
Kumho 857... They are the only tires that last well on our and mini vans.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-11-2014, 07:22 AM   #39
sail2liv's Avatar
I use the tire minder system on trailer and truck.....it reads out continuous pressure/temperature....and can be set to alarm at pressure and temp you want....so will alarm if increase or decrease.....even though truck has own system I like knowing the temp and not having to put a gauge on the tire.....this old back does not like to bend down if it does not have to....good luck with your new tires.....I drive 56-58 mph..if you are going 62 might be worth it to back down 4 more miles per hour...when I travel the interstates almost all RV s pass me three times on a 4 hour stretch....and I stop at every rest area.....so figure out that math if you can.....
People with TV at limit have to reduce pin or hitch weight that will put more weight on your tires.....ST tires should carry 80% of the max allowable at max pressure if possible.....would not hurt to get a CCAT readout on each axle and each side of trailer
Old 07-11-2014, 07:30 AM   #40
dcheatwood's Avatar
I'm trying to understand this statement. Confused.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
tire, tires
