Old 07-19-2014, 10:52 PM   #51
I've read this week about a bunch of RV'ers that had TPMS and it didn't help them a bit when their tires separated. In their case, they slowed to a stop quicker, and might have done less damage to their fenders, siding and underbelly.
In your case, it was TPMS was well worthwhile. For just over $200, it's something that a serious trailer owner shouldn't be without.
And one of the first steps is junking any rubber Schrader valves/air stems in favor of metal ones.
Bamaman is offline   Reply With Quote
Old 07-20-2014, 06:49 AM   #52
RPAspey's Avatar
X2....TPMS = piece of mind and another tool to make camping a bit less like work. Rubber valve stems = as much trouble as China bombs. Those stems are generally only good for 65# max.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-20-2014, 07:18 AM   #53
indybp57's Avatar
Anyone have experience with Karrier Loadstar STs? We have about 4800 miles on the ones that came on our Roo. So far they look great.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 07-20-2014, 08:49 AM   #54
Kaadk's Avatar
Those are what came on ours. So far no issues but we've only had it since last year. I'm not sure how many miles they have, as I haven't kept track. I just keep an eye on the tread and figure I'll replace them when they start to look worn.
Actually, that brings up a topic I've been pondering. Do you rotate the tires on a trailer like you do with your vehicle, or do they tend to wear evenly so no point?
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 07-20-2014, 10:29 AM   #55
DaveSchwartz's Avatar
Entering 'rotating' into the search box above will give you some reading to do before hijacking this thread... at least 6 threads on the topic on the first page of results.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-21-2014, 12:02 AM   #56
I'm sorry, but I certainly am not going to buy any tire I never heard of, especially if they're from China. And I cannot go with Goodyear Marathons with their terrible reputation.
What's ironic is that the owner/moderator of a couple of large RV owner forums is on a long RV trip. Two Will Pop tires blew yesterday and did serious damage to the fenders and siding on his 5er. He used duck tape to patch things up temporarily.
On an RV, the following LT style E rated tires are the only brand/models to get:
Bridgestone Duramis R250
Cooper Discoverer Maxx
Maxxis M8008 (ST tire)
BFG Commercial T/A
Michelin XPS Ribs
Goodyear G614 RST (ST tire)
My new fifth wheel's scheduled for production 7/22, and I've decided to change to the Bridgestone R250's--one of two tires consistently bragged on as being trouble free and long lasting. The Michelin XPS rib is the other universally approved tire, but it's more expensive.
Old 07-21-2014, 06:08 AM   #57
Herk7769's Avatar
Bamaman,
Those tires are pretty heavy duty and most require tire pressures over 100 PSI. On a travel trailer made without shocks, you are going to shake it to pieces in short order with double over range tires.
They may outlast several trailers.
Properly matched tires to (load range to camper weight) is more important than manufacturer. Once you have the correct load range tire for your rig; THEN you can talk about who makes it and where it was made.
Even if you could find one, putting a G range tire on a D range trailer for example, seems a total waste of money, IMO.
FYI, my Marathons are about to "age out" with more than 50% tread remaining and over 25,000 towing miles on them.
A new set of Marathons will be going on next season.
HAM CALLSIGN - KC3FFW
Old 07-21-2014, 08:22 AM   #58
Herk: Only the Firestone G614's are G rated, and only they require high pressure and special wheels. My fifth wheel came with wheels that'll accept them. But $400 per tire is very expensive, even if the tires are of very high quality.
The rest are E rated tires, and 80 psi is usually the max on them. I have comparable tires on my 3/4 ton truck, and I run 55 psi when not towing anything. They're not at all harsh.
Do yourself a favor and research the current Goodyear Marathon tires further. Because of the brand name, there are many on the road. And now they appear just to be another Chinese Will Pop tire. Marathons are one of the tires universally complained about.
Old 07-21-2014, 08:44 AM   #59
Where should we go next!
Offagain's Avatar
For what it's worth. My old Marathons lasted me 6 years trouble free. I replaced them mid trip due to an air leak in the sidewall of one of the tires. I replaced all due to their age and signs of drying out.
After I had posted pics of my blowout, others responded that it looks like I had encountered some type of road hazard that caused the tire to fail. The tire dealership that replaced the two tires hinted at the same cause.
I held on to the tires because I wanted to contact Goodyear. I did. This was their response.
Jim:
Thank you for contacting our web site. We are always concerned when we
learn that we have failed to exceed a customer's expectations with regards
to our product or service.
All Goodyear tires come with a six year limited warranty. During the first
12 months or 2/32" of tread wear, whichever comes first, tires removed from
service due to a covered warranty condition will be replaced with a
comparable Goodyear product free of charge, mounting and balancing are
included.
Tires not eligible for free replacement that are removed from service due
to a covered warranty condition will be replaced with a comparable new
Goodyear tire on a prorated basis for up to six (6) years from the date of
purchase. (Without proof of purchase the date of manufacture will be used
to determine eligibility.)
Without inspecting the tire in question we could not comment as to its
cause or condition.
Goodyear relies on a network of retail locations, both Company Owned and
Independent to determine warranty eligibility. If your tire is still
available and has not been inspected by an authorized Goodyear retailer we
would suggest you do so. You can locate your nearest authorized retailer
by calling toll free 1-800-466-3932 or on our web site at the following
path: http://www.goodyeardealers.com/
If after inspecting your tires the authorized retailer is unable to assist
you please ask them to contact our Customer Assistance Center toll free at
1-800-321-2136 to discuss your situation with one of our Customer
Assistance Professionals. Please reference file number 1412625.
Kathe
Consumer Relations
I decided not to argue the point after suspecting I indeed may have run something over. I took the tires to my local Costco to have the tires disposed of. I asked them to look at both tires and he pretty quickly came to the conclusion that it looked as though something had punctured the tire. Not so obvious on the one that was shredded, but on tire number 2.
I'll just have to have faith in the new ones seeing the originals lasted me 7 good seasons.
Ford F-150 4X4 Supercrew Ecoboost
Surveyor SV291
Equalizer 4-point 10K lbs.
Offagain is offline   Reply With Quote
Old 07-21-2014, 08:44 AM   #60
Herk7769's Avatar
OK, but still putting a new set of Marathons on when these are ready. I will, of course, report as soon as these explode with no warning.
Most tires fail due to road hazard and operator error (under inflated for load).
tire, tires
