Old 07-04-2016, 07:24 PM   #11
MaineCampingFan's Avatar
Originally Posted by Stormrider151 View Post
"Two is one, one is none". I like that. Thing about us Firefighters is we are always thinking "what if?". I'm the same way. Drives DW nuts. But I've got to keep her safe. Well done brother.
Drive DW a little nuts as well. But, it's a short drive. .
2015 Freedom Express 246 RKS
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2018: Still Not Enough
MaineCampingFan is offline   Reply With Quote
Old 07-04-2016, 07:30 PM   #12
Crusadernoob's Avatar
Millions of vehicles stow a spare like this, as stated, a single indentation is no worry, if it is actually worn into the sidewall of the tire from movement it is not secured tight enough.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 07-04-2016, 07:30 PM   #13
Originally Posted by Oaklevel View Post
Thanks looks like something that should be checked. Let us know what solution that you come up with.
What I've done for now is to add a dense foam pipe insulation between the square tubing and the spare (see photo). And made sure I can get at the stem to check the tire pressure. The "plywood donut" seems the best option if I want to keep the spare in the same spot.
In my case, it wasn't simply indented or impinged, it wore material from the sidewall. Replacing it was really the right thing to do. Ironically, the service center underfilled it
Old 07-10-2016, 02:28 PM   #14
Commercial Member
If the sidewall was worn it was not properly tightened in the first place. Bet if you complained to dealer tyhey would tell you it was your responsibility. If they told me that I would ask for the page in the owners manual that tells me the torque spec
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 07-10-2016, 02:34 PM   #15
Originally Posted by merlbren View Post
I cut a piece of ĺ treated plywood on top of my tire to protect it, and keep water from standing around bead of tire and rusting rim.
Same here...
Mmwtdh is offline   Reply With Quote
tire
