Old 06-05-2014, 05:08 PM   #1
Explorer
Spring Time, Brakes & Bearings
Had some time to do my annual breaks and bearing check.
I also took the tires in to have heaver valve stems installed for the new TPMS unit I got for Christmas(yep I lag).
All bearings and races looked great so that was easy.
I found one broken wire right at the break magnet. I might try soldering it and saving as a spare, Ill clean it up and see.( the brake was not working at all for who knows how long in the last year)
One break shoe warn more than others, replace.(with full assembly; look below for info)
One grease seal blown and one that had miner issue. I donít know if synthetic grease is tougher or if break cleaner is getting weaker but it was hard to clean up the mess.
Two of my brake drums have decent grooves from their magnets and the same magnets are looking worn. I donít have a lot of experience with these electric brakes. Do I have the drum surface milled down? Do I just replace the magnets?(the brake shoe surface of the drum looks great) Well I figure Iíll deal with them next year.
An interesting price note: break shoes $27, break magnet $30; a full Dexter backing plate assembly $50. A big thanks to the parts-counter-guy for informing me, even made the job quicker.
I greased all the shackles in the suspension and took some time to look for any other problems like broken welds or loose brackets.
I sure like getting under my camper to know whatís going on. I think about how long Iíll want to do this myself, but I still have a few more years in me.
A Yearly Check Is Good
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 06-05-2014, 06:05 PM   #2
H2oski
While your replacing brakes, check out Nev-R-Adjust for $55.00.
12" Nev-R-Adjust Electric Brake Assembly for 6K Axles - RH Dexter Trailer Brakes 23-459
Replaced all of mine over a 2 years period while inspecting the bearings.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 06-05-2014, 09:22 PM   #3
Explorer
Looks the same as what I got for $50 each at a local shop
John
Old 06-05-2014, 09:30 PM   #4
PPST OGCDG
Frank-VA's Avatar
There was a very in formable article in the May 2014 "Trailer Life" about servicing brakes and Bearings
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 06-05-2014, 09:38 PM   #5
Was your brake assy not (10in x 2) for your unit? Youroo!!
bearings, brakes
