Old 08-17-2017, 07:17 PM   #1
Springs
I noticed when my truck is un-hitched from trailer my overload springs are flat against the other springs. I thought they had space between them some time ago. Is this normal?
mfMcFroggierPod is offline   Reply With Quote
Old 08-18-2017, 10:35 AM   #2
It would probably help to know which truck you have.
It's normal for some models to have the overload springs conformed to the main springs and it's not normal for others.
Give us the model and some members with the same model can look at theirs and let you know what they find.
Gotta go campin!
Old 08-18-2017, 07:26 PM   #3
Chevy 2500
Old 08-18-2017, 07:59 PM   #4
Not sure what year yours is, but here's mine on a 2016 model.
Name:	Sierra 2500HD OL Spring.jpg
Gotta go campin!
Old 08-18-2017, 08:06 PM   #5
Thank You for the picture.
Mine is a 2007 NBS
I thought that how mine used to look, now they are tight against each other.
Old 08-18-2017, 08:07 PM   #6
I will have to investigate...
Old 08-18-2017, 08:29 PM   #7
How much weight do you add before you notice they go tight against other springs?
The only variable is I added a 40 gallon aluminum tank that weights -100#'s
I noticed this even when it is empty.
Old 08-19-2017, 01:51 PM   #8
That picture is with the 250# 5th wheel hitch in the bed.
I'm not sure how much it takes to get them to sit on the pad, but I've put 400# on the back plus the hitch and they don't touch. I do know that hitching up the 5er makes them touch. But it has a pin weight of about 1800 lbs.
Gotta go campin!
Old 08-24-2017, 10:30 PM   #9
Bama what is your GVWR?
Old 08-24-2017, 10:36 PM   #10
Just as confused as you
Scrapper's Avatar
Since your talking about it being un-hitched, I would think that means your springs are getting weak.
Richard & Jill
Old 08-28-2017, 10:33 AM   #11
Ths GVWR is 9600Lbs.
Gotta go campin!
