Old 07-21-2012, 04:00 PM   #1
BJAY's Avatar
Squeaky suspension
Our 2011 trailer already has squeaky suspension(dual axle, leaf springs).On our previous trailer I found that the shackle plates were shiny where they rub against the spring eyes. The only way I know of getting grease in that area is to modify the bolts by drilling a 1/32" hole along the centre of the bolt, cross drill at the centre of the bolt, then add a grease fitting in the bolt head. The grease then flows thru the bolt, fills the bushing from the centre out until some grease gets forced between the shackles and the spring. It was a bit of a job on the old single axle(6 bolts) but worked well. The new dual axle has 14 bolts. I was hoping someone has an easier way of fixing this problem.
Bill
Bill & Joyce
2012 Hemi Ram 1500 Quad cab 4x4
2011 Wildwood 22RBXL-Backpack Ed.
BJAY is offline   Reply With Quote
Old 07-21-2012, 04:18 PM   #2
Bill
Wet Equalizer Bolt with Locknut and Grease Zerk for Double-Eye Springs - 3" Long TruRyde Accessories and Parts 126B2
Old 07-26-2012, 09:23 PM   #3
BJAY's Avatar
Thanks Dunnc,
Checked locally and find they want $3.49 for these bolts. My trailer has only about 1000 km on it so I will likely drill the existing bolts on my lathe and add grease zerk. Someone on the site you mention said there was no ball in their zerks. I found zerks with ball to prevent dirt entering or grease escaping.
Bill
Bill & Joyce
