Old 10-01-2014, 08:03 PM   #1
Price's Avatar
Stay with 15" rims or upgrade to 16" rims?
After reading a few posts about Chinese tires I've decided to replace mine. My question is should I buy a set of bigger wheels as well? Isn't bigger better? Is the cost not worth the hassle?
I haven't priced or bought a set of trailer tires before and instead of reading trough hundreds of pages of posts I figured I'd ask.
I have a 2014 Cherokee 264L-PB with 15" rims
Thanks in advance.
Tim & Mary
SE Kansas
2013 Ram 2500 6.7 Diesel
Price is offline   Reply With Quote
Old 10-01-2014, 08:32 PM   #2
xs1ve's Avatar
15" are the most popular size made. I would think you would have more options in that size than any other and likely at a lower cost.
Jerry & Sheryl
2015 Rockwood 8280WS
2012 Ram 1500 Laramie 5.7 Hemi 3.92 RR
xs1ve is offline   Reply With Quote
Old 10-01-2014, 09:02 PM   #3
ARLO
I would stay with 15's but go with a heaver load rating.My personal choise was load range E, 10 ply rated on both trailer and truck.
rlocicero is offline   Reply With Quote
Old 10-02-2014, 07:09 AM   #4
Almost every time I read about about someone going from 15's to 16's it doesn't end well.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 10-02-2014, 02:13 PM   #5
Price's Avatar
Why?.....Will the 16's cut off Earth's gravitational field and my TT will soar off to the second star on the right.
Sorry to funny not to say.
Tim & Mary
SE Kansas
Old 10-02-2014, 02:37 PM   #6
Some times if you go up to 16s from 15s with a higher rating they call for more tire pressure and the rims may not to able to handle the higher pressure. I would make sure that your new rims are able to handle the increased pressure. Good Luck
whj77372 is offline   Reply With Quote
Old 10-02-2014, 02:41 PM   #7
What are you planning on upgrading to???
The good part about upgrading the rims and tires is that you can get rims and tires that will actually carry the weight of your trailer!
chiro is offline   Reply With Quote
Old 10-02-2014, 03:04 PM   #8
Price's Avatar
Good point.
Tim & Mary
SE Kansas
Old 10-02-2014, 03:25 PM   #9
offroad's Avatar
On my last rig with a GVWR of about 10K, I upgraded to 16" tires and wheels. It was a big expense, and the wheel wells barely had the room for 225/75-16's.
Our current TT has a GVWR of 8849lbs, I upgraded to GY Marathons in LR D but opted to stay with the 15" wheels it came with.
That gives me more tire capacity, than the entire rig weighs including the tongue weight. FR shows your model at about 1000lbs less than mine, so I think you'd be fine just going up to LR D's and staying with the original wheels.
The 15" wheels don't have that much capacity (neither do the axles), but I'm not seeing posts about wheel failures.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 10-03-2014, 12:33 PM   #10
Helmsey's Avatar
I went from 15" ST to 16" LT on our last 5er and was happy with my decision. Since I bought new wheels and tires I was able to resell my old stuff and make back a decent chunk of change, helps offset the cost of the new equipment.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
upgrade
