Old 11-13-2013, 10:15 PM   #1
Steadyfast bars
I have a 2011 Flagstaff V-Lite 30 WRLS and am considering installing Steadyfast bars to help eliminate trailer shaking after setup. Do they work? Will installation damage the frame?
chasbo70 is offline   Reply With Quote
Old 11-13-2013, 10:18 PM   #2
Fulltime family RVer
Their installation is very typical of triangulation stabilizers so no frame concerns. The maker of the SteadyFast system made a good argument on one of my blog posts - I'd actually give them a shot if I had to buy a system next time.
Old 11-14-2013, 01:29 AM   #3
Plug It Right
We use another brand. Ours are permanently installed and we have had no interior movement for over 8 years. Hugs, Di
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.http://www.plugitright.com/5thwheelREDO.html
Dutch & Di is offline   Reply With Quote
Old 11-14-2013, 06:02 AM   #4
Firefighter969's Avatar
I installed JT Strong arms and they work great also use Xchocks to
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 11-14-2013, 07:13 AM   #5
5erDriver's Avatar
I don't have the Steadyfast on my 5er cause of where the spare wheel is located. It would need modified. I still might do it. However my good friend had it his last camper and put it on his current one. It is ROCK SOLID. I wouldn't hesitate at all. I've seen it in action and its great.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 11-14-2013, 07:18 AM   #6
Dave_Monica's Avatar
I've had the SteadyFast stabilizers on our camper for 2 years and am satisfied with them. Also use homemade chocks that fit between the tires (like rotochock) and a jackstand on each side close to the axles...eliminates most of the movement.
Dave
Old 11-14-2013, 08:04 AM   #7
camper1999's Avatar
I use the bal stabilizers on my 5th wheel with xchocks on the tires. The trailer is rock solid, no shaking. I chose the bal brand because they are a great cheaper then most brands and they work great. This is not my trailer, but I only put the front ones on mine for the side to side motion, that is all I needed.
2011 GMC 2500HD Diesel
camper1999 is online now   Reply With Quote
Old 11-14-2013, 09:44 AM   #8
Thanks for the advice and particularly the different product you introduced to me of which I wasn't aware. Now I'm like a kid in a candy store!
Old 11-14-2013, 02:59 PM   #9
TURBS's Avatar
Its hard to tell from you profile pic and since you don't have your unit listed in your signature line it appears you have a sabre.
If so the spare tire is located in the front storage bay and hangs below frame ?
If so you can still add stabilizers as I did mine. "Look in profile"
You don't need two side to side in front.
One from d/s frame to lower pass. Side leg . "Side to side"
And one from pass. Side frame to pass. Side leg "for and aft"
All you need is triangulation and that method cures it.
Imo you don't need two criss crossing in the front "side to side" and two either side going "for and aft"
Mine is as solid as others with the for mentioned "four bars"
Turbs
Old 11-14-2013, 03:02 PM   #10
TURBS's Avatar
Can be seen in this pic.
You can also see spare hanging down.
