Old 08-11-2014, 08:48 AM   #11
wmtire's Avatar
Originally Posted by f1100turbo View Post
Attachment 60187
These are what I have.
All metal.
TURBS
"SABRE OWNERS UNITED"
ALMOST all metal, Ron. There is a rubber grommet on it, that is what makes the air-tight seal for your clamp-in type stem.
This is a good example of the easy confusion. We need to try and quit saying "metal". All stems have rubber and metal. Even what is called a rubber stem, has a brass internal tube/core covered in rubber..
2011 Flagstaff 831 RLBSS
I'm currently boycotting any company that sells items I can't afford
Old 08-11-2014, 08:50 AM   #12
offroad's Avatar
HP Valve Stems
I have ordered a set of GY Marathons (225/75-15 in Load Range D), for a 2015 Rockwood 8329SS we will take delivery of in a month or so.
Also need to upgrade the valve stems to HP versions when the tires are swapped and it seems there are two types, full steel and steel lined rubber.
I had someone tell me the full steel models were prone to leaking due to the rubber gaskets not fully sealing on all types of wheels.
Which type is best and what size hole will the wheels on this unit have?
These wheels seems to be what Rockwood is currently shipping, can anyone provide links to HP valve stems that will fit those wheels?
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 08-11-2014, 08:52 AM   #13
TURBS's Avatar
Originally Posted by wmtire View Post
ALMOST all metal, Ron. There is a rubber grommet on it, that is what makes the air-tight seal.
Correct the rubber seal/ grommet fits inside the hole from the back side .
TURBS
Old 08-11-2014, 09:05 AM   #14
Thanks WMTire. Good info. Our local tire dealer had explained that to me also. The problem we had was finding the clamp-in (nut and washers) to fit the rim properly. We tried two different brands and they wouldn't give me a tight/leak proof fitting due to the curvature on the rim. We tried several auto/truck/rv parts store nearby but no one had anything different. We believe a manufacture is out there though.
Justice is offline   Reply With Quote
Old 08-11-2014, 09:06 AM   #15
wmtire's Avatar
See post #9 for the TR600HP "brass" stems.
They do make different types of clamp-in stems for different wheels, depending on how the valve stem hole is made in relation to the wheel lip.
The common TR416 clamp-in stem will work in many wheels, but not all. Most tire stores will carry the TR416 in stock.
I don't know the exact number of the valve stem I'm thinking of, but will find it for you.
Old 08-11-2014, 09:12 AM   #16
wmtire's Avatar
Here's another version of clamp-in stem that works on the rims, who have outer lips that don't have enough clearance to get a nut/socket to turn. The nut on this type if offset a lot higher, which gives you more room to turn it.
Xtra Seal 17-428 - Bolt-In Valve | O'Reilly Auto Parts
Dave_Monica uses these on his, as me and him have discussed it.
There are also others, as Turbs has in his post #10....which I think is a TR416 though.
Old 08-11-2014, 09:20 AM   #17
Yes I do have the TR600 HP type on now. Unfortunately we couldn't find the screw type the day of change out of tires. My local tire dealer advised they have seen the rubber seals degrade on the clamp/screw types also, they showed me a couple they had recently replaced.
Old 08-11-2014, 09:24 AM   #18
We tried the TR416, couldn't get a good seal. Will check out the others you mentioned used. Thanks you guys have been helpful.
Old 08-11-2014, 11:08 AM   #19
offroad's Avatar
Thanks for the link, for a load range upgrade like mine would you recommend a snap-in TR600HP, a clamp-on TR416 if they fit or the 17-428 if the TR416's won't fit?
All of these are rated for 100psi, and if I later decide to install a TPMS is a clamp-on valve preferred?
Old 08-11-2014, 11:13 AM   #20
wmtire's Avatar
Yes, the clamp-in type stems are preferred for the TPMS systems that screw onto the end of the valve stems.
tire, valve
