Old 07-20-2016, 02:30 PM   #11
CaptnJohn's Avatar
Originally Posted by pledbetter View Post
I've got the Air bags on my F250 all I have to do is push a button and my built in compressor cranks up about 30 psi which levels out my bed to fifth wheel...drain the pressure when we're unhitched and get a smoother ride...U was told the conversion makes your 250 better than a 350...about $600 to do it....I have the Anderson hitch at 32 lbs and. B and W ball...flat bed in 5 minutes
Not quite ~~ My 2016 F250 is close in many ways to my 2016 F350 but the 250 does have a slightly smoother ride. That is where it ends. The 350 has a much higher payload rating which air bags, additional springs or anything else can change. Air bags will level sag which will help stability, especially if in a payload overload situation. The 350 has higher rated wheels/tire, axels, and more even though the drive train can be the same. The 250 is limited to a 10,000# GVWR, not so the 350. When buying new the 350 is priced within $800 of a 250 and can often be bought for less. I have pulled 5ers to about 11,500 with the 250 but when getting much over that the 350 is the way to go even though both can be rated at the same 15,600.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 07-21-2016, 06:50 PM   #12
I installed suspension air bags in our Pathfinder, and am very pleased with the results
Denny B is offline   Reply With Quote
suspension, upgrade
