Old 07-19-2016, 09:29 PM   #1
Suspension Upgrades (beefin up shocks)
Can someone explain what process or parts would be required to beef up the shocks and suspension?
I've read about air bags and blistens.
I want to eliminate rear end sag, improve driving experience and allow for a heavier load in the event i need to load it up heavier than usual.
I should note that I will be installing front/rear sway bars and steering stabilizer as well.
2014 FR3 25DS
teamjendy is offline   Reply With Quote
Old 07-19-2016, 09:32 PM   #2
davel1971's Avatar
what type of vehicle are you asking about?
David & Lynn
Old 07-19-2016, 09:41 PM   #3
Ditto. Vehicle would help.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Stock for now.
Days Camped 2015: 17
Days Camped 2016: 28 so far
DocGTO is offline   Reply With Quote
Old 07-19-2016, 10:01 PM   #4
SilhouettePenny's Avatar
His signature shows a 2014 FR3 25DS
1999 F250 w/7.3L Diesel
2014 Silhouette 299RKDS
Nights Camped 2016 - 21
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 07-19-2016, 10:03 PM   #5
Yes sorry. 2014 fr3 25ds
2014 FR3 25DS
Old 07-19-2016, 10:13 PM   #6
davel1971's Avatar
I don't see any reason why you would need to. The stock suspension should easily handle the weight, up to the GVWR of course. Are you saying it doesn't have any sway bars or steering stabilizers now? I find that hard to believe.
David & Lynn
Old 07-20-2016, 02:49 PM   #7
May I ask a related question. We have a 2016 MBS 2401 Forester with a Hellwig sway bar installed. Yet, it dances way too much and seems to be bouncing off the suspension support with a loud bump on most uneven surface/curves. How can I upgrade to stabilize the vehicle and eliminate this noise?
HansSchulz is offline   Reply With Quote
Old 07-20-2016, 02:58 PM   #8
Retired Retail/Importer
I've got the Air bags on my F250 all I have to do is push a button and my built in compressor cranks up about 30 psi which levels out my bed to fifth wheel...drain the pressure when we're unhitched and get a smoother ride...U was told the conversion makes your 250 better than a 350...about $600 to do it....I have the Anderson hitch at 32 lbs and. B and W ball...flat bed in 5 minutes
pledbetter is offline   Reply With Quote
Old 07-20-2016, 03:01 PM   #9
Before changing anything you should consider doing the Cheap Handling Fix (CHF). Do a search for it on the Forum. The Ford F53 chassis has 2 positions for the sway bars. By stiffening these up handling is much improved. Many FR3 owners have done this with great results.
dutiful Don is offline   Reply With Quote
Old 07-20-2016, 03:09 PM   #10
[QUOTE=HansSchulz;1264880]May I ask a related question. We have a 2016 MBS 2401 Forester with a Hellwig sway bar installed. Yet, it dances way too much and seems to be bouncing off the suspension support with a loud bump on most uneven surface/curves. How can I upgrade to stabilize the vehicle and eliminate this noise?[/QUOTE
Please explain, are you saying that you are bottoming out the jounce bumpers on the rear axle when hitting bumps?
Go to the Mercedes Brenz Sprinter sub forum, the Forester sub forum, or the Sunseeker forum of the Motor Home section
Post your question there and be specific on what is happening. Unless you are severely overloaded and the jounce bumpers are almost touching the axle, they shouldn't be bottoming out. Are you sure you don't have something loose in one of the rear basement storage compartments that is bouncing and making a thumping noise when you go over a bump.
I know it can happen, because it happened to me. We have a 2017 BMS 2400WS and I had a milk crate with some one pound propane cylinders stored in the garage compartment right behind the drivers seat the first time out. Each time I would hit a bump, I would hear a thump. After about 15 miles worth of this thumping noise, I was able to stop to wee where the noise was coming from. Since everything looked fine, I started going through the compartments and recreating the sound. when I got to the compartment with with the milk crate, I lifted it up and let it drop. lo and behold there was my noise problem. A little repacking and the noise was gone.
I am not saying this is the problem, but rather that there is all kinds of information available on suspension enhancements for the Sprinter Chassis, along with knowledgeable forum members who frequent those three sub forums.
Sherman
ShermanD is offline   Reply With Quote
suspension, upgrade
