Old 04-23-2016, 01:27 PM   #231
Commercial Member
Originally Posted by Oaklevel View Post
snip
My question that no one can seem to answer is how long have ST tires been out there my first two campers both 24' duel axle came with P rated tires from the factory......
ST type tires have been around for 20+ years
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 04-23-2016, 05:07 PM   #232
Airdale's Avatar
snip
My question, that no one can seem to answer, is how long have ST tires been out there? My first two campers (both 24' duel axle) came with P rated tires from the factory.
Passenger tires are still used by some trailer manufacturers. I recently attended an “outdoorsman” show that featured a great many large bass boats on dual axle trailers. About 35% of those trailers were fitted with “P” tires. I did the math, all had been properly derated for trailer service.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 07-23-2016, 05:08 PM   #233
Airdale's Avatar
Tire load index
With new rules governing tariff taxation on foreign tires, specifically requiring most foreign manufacturers of ST tires to provide a speed rating on every tire’s sidewall, we are seeing them using a tire service description with a speed letter for the tire. Although the load index section of the service description is not the official load capacity measurement for ST and LT tires they are still allowed. Probably because someday that form of load capacity determination will be standardized for all DOT highway tires.
One of the shining problems with some ST tires is the fact that the Load Range system used for determining the tire’s load capacity is not always accurate without further explanations. The ST235/80R16E tires are, or have been, manufactured in three distinct load capacities, all identified as LRE. The actual load capacities can be 3420#, 3500# & 3520#, all at 80 PSI. The new ST tires with load index and speed letters will have a 123 load index for the 3420# tires and a 124 load index for the 3520# tires.
Nice to know information when your OE tires are really close to being maxed-out, and a need to know fact, when replacing 3520# tires that have been used on 7000# axles and you’re thinking about using a name brand with the 3420# tires which do not qualify for 7000# axles.
Old 08-04-2017, 11:38 AM   #234
Originally Posted by Airdale View Post
Please don’t take this as a harsh answer. It’s just based on facts that people don’t like to accept.
For a long time know I’ve been doing the safety side of tires. I’ve been branded all kinds of bad and have even been banned from tire threads - sometimes - because of my harsh postings.
Tire dealers cannot over ride, trump, or any other way, do less than the vehicle manufacturer. Because? The vehicle manufacturer, in the eyes of the governing body (DOT) has sole authority for Original Equipment tire and rim fitments. They are required to put their (MINIMUM) selections along with recommended tire inflation pressures for them on the federal certification label and display it on your trailer.
Tire industry standards (aftermarket) consist of a set of standards from tire manufacturers, the Tire & Rim Association (TRA) and Rubber Manufacturers Association) RMA. They are very consistent and found in any tire manufacturer’s Standard Operating Procedures (SOP) manuals and PDF files found on the internet.
For a tire dealer or any other tire shop to change your trailer tires from one design to another is considered a misapplication. In fact, any change not recommended by your trailer manufacturer in the Owner’s Manual for your particular trailer is a misapplication. RV trailer tires do not have the same industry standards as the automotive industry with their pre-selected replacement lists and approved “plus sizing” procedures.
Why a trailer manufacturer selects and installs the tires on your trailer is immaterial. It was their decision to make within the guidelines provided by the governing body (DOT). None of the designs such as Passenger (P), Light Truck (LT), Special Trailer (ST), Hybrid - ties with a LT prefix marked “for trailer service only” or any of the wide range of medium to heavy duty truck/trailer tires are exempt. But, no matter what their design they are all installed in accordance with FMVSS guidelines. Not to be confused with guidelines for the trucking industry.
The bottom line. Once your drive off with your new or used trailer, it’s yours to do with as you see fit. I encourage you to be safe with everything including your tire selections. Below is a version of minimum industry standards. It’s from Michelin - hard to find them admitting they don’t control everything.
(Click on the tab "changing sizes or specs").
http://www.michelinman.com/US/en/help/how-to-choose-tires.html#tab-4
This seems like sound advice. Maybe you could help I'm wondering about tire rotation. I rotate my truck tires about every 6000 miles. Should I be doing that with my camper. Is there a known pattern I should follow?
It's a tandem axle and nitrogen filled tires.
Also I don't have nitrogen how do I top off my tires. Should I look for a hi end gage to check them? I don't like how much I lose when I check and don't want to top off with just air.
ourjoyride is offline   Reply With Quote
Old 08-04-2017, 01:59 PM   #235
I'd rotate the trailer tires just like on a car using the "X" pattern. Better yet, rotate side to side one time and "X" the next. That way every tire will get to "ride" in every position and wear will be distributed evenly.
As for inflating a Nitrogen filled tire with Compressed Air? Go ahead. Air is 78% Nitrogen to begin with. Other elemental gases will eventually migrate through the tire's inner liner leaving Nitrogen behind.
While I was still "in the industry" I spoke with one of the largest suppliers of Nitrogen "generators" for the tire industry. He noted that a tire filled with Compressed Air would test at regular intervals with increasing percentages of Nitrogen. Stands to reason as the tire industry Nitrogen Generators are merely large membranes that allow gases other than Nitrogen to escape, holding back the Nitrogen to be used to inflate new tires. The process is the same in a tire, it just takes longer.
Have anyone ever noticed how a new tire might need some extra air added in the first year and after that it it doesn't need air as often? This is what happens as the Nitrogen concentration in a tire filled with Compressed Air increases.
In short, no need to buy a tank of compressed Nitrogen or for that matter any special "pressure gauge". Remember that 78%? It's clearly the majority of gas in ALL tires.
For those that have heard about "Compressed Air" being "Wet", a small silica gel compressed air dryer can be purchased for under $90 and installed on on a lock on tire inflator chuck with pigtail. Then add air from that Convenience Store compressor (or your own portable) by just through the dryer. Yes, "Air" contains about 1% water at sea level but after it passes through the desiccant, it's as dry as it gets.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-04-2017, 03:51 PM   #236
How many people actually use a convenience store air compressor anymore? I fill my tires at the beginning of a trip with my home compressor and after 20 feet from the compressor, goes through a drier. I use my compressor for painting so I need dry air.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is online now   Reply With Quote
Old 08-05-2017, 02:59 AM   #237
Airdale's Avatar
Basically tire rotation is a product of the tire industry. My recommendation is to follow the requirements found in the tire warranty booklet and/or what is in the Vehicle owner's manual.
Personally I've put a lot of miles on RV trailers and single/dual axle boat trailers. I never found the need to rotate the tires. They are just follow along tires and get very similar wear front or back or side to side.
Old 08-05-2017, 09:41 PM   #238
If your tires are wearing evenly be it a trailer or a truck, you don't need to ever rotate tires.
The reason there are intervals for rotating tires...most people are too stupid to measure tire depth so if you just have them rotate at a specific interval...it all works out.
Old 08-02-2018, 04:18 PM   #239
fleabert's Avatar
fleabert is offline   Reply With Quote
Old 08-02-2018, 06:19 PM   #240
Commercial Member
All new tires "grow" a bit. This means the internal volume increases so the pressure drops. When we test tires the test spec requires a controlled waiting period and re-inflation to take tire growth into account.
led pad
