Old 02-01-2019, 11:19 AM   #241
I am looking to replace my tires in the spring, do you have to balance trailer tires?
ART55 is offline   Reply With Quote
Old 02-01-2019, 11:23 AM   #242
wmtire's Avatar
You dont have to balance any tire.....unless you want it to ride smoother, and not have vibrations and/or irregular and premature tire wear.
It's better to balance your tires on campers to minimize vibrations and such to it. This includes vibrations to the cabinets, slideouts, and everything else.
2011 Flagstaff 831 RLBSS
Did you know, according to Google: Pepsi was once the 6th largest military in the world?
Old 02-01-2019, 11:24 AM   #243
MilCop4523's Avatar
I would and have with my 4 trailers we've had starting with our 2012 FR. The way tires are manufactured today it makes sense to high speed balance them for a more even tread wear.
and I would not be surprised if people argued they wouldn't. But I bet if you asked them they would state that their car and TV tires are high sped balanced for extending tread wear life and a smoother ride. Trailer IMHO should be no different.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 02-01-2019, 11:24 AM   #244
Do you HAVE to... no... but it is always recommended to balance tires.
For the few dollars it costs when replacing the tires why wouldn't you?
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 02-01-2019, 01:45 PM   #245
Herk7769's Avatar
I highly recommend it for travel trailers. Most do not have shocks so bounces from out of balance tires are transmitted directly to the contents.
HAM CALLSIGN - KC3FFW
Old 04-17-2019, 01:05 PM   #246
automatic tire balancers
as anyone tried to use or have experience with automatic tire balancers on travel trailers...specifically 14 in tires? I was looking at the centramatic automatic tire balancers that claim to balance the entire tire and hub assemblies.
bigred123 is offline   Reply With Quote
Old 04-17-2019, 01:45 PM   #247
Iwannacamp's Avatar
Originally Posted by Tireman9 View Post
All new tires "grow" a bit. This means the internal volume increases so the pressure drops. When we test tires the test spec requires a controlled waiting period and re-inflation to take tire growth into account.
Back in the 90's when 4-wheeler tires were becoming monster truck tires... The rednecks would over inflate the ATV tires x2 or x3 and "stretch" them. You could get some height out of them.
2017 Puma 297RLSS
Old 04-19-2019, 03:50 PM   #248
Commercial Member
one advantage of "balancing tires is you can get a feel of the tire overall quality based on the amount of weight needed. If you have 3 tires needing 2 to 3 OZ and one needing 6 or 8 then something may be wrong with that one tire or it may not be fully seated or properly balanced. You can also see it there is a significant out of round by watching the tire as it spins. You can balance almost anything. I have even seen a demo of a cinder block being balanced but obviously an out of round tire would have a bad ride even if it was perfectly balanced on the machine.
A test would be to ask the manager what they consider their upper limit on weight BEFORE they start balancing your tires.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 04-21-2019, 04:46 PM   #249
Tires
I am considering Sumitomo 10ply highway tires. I have them on my truck and they don't sway at all.
michaelangelo4 is offline   Reply With Quote
Old 06-25-2019, 10:03 PM   #250
oldhippie-froggie's Avatar
My Grey Wolf 22RR came with Castle Rock ST205/75-14 rated 1760 lbs at 50 psi. The max rating on the trailer is 7600 lbs. By the OP I'd say my OE tires are under rated for the 22RR.
Thoughts? Am I thinking straight about this and should I definitely upgrade?
oldhippie-froggie is offline   Reply With Quote
led pad
