Old 08-28-2013, 03:30 PM   #51
Herk7769's Avatar
Originally Posted by Windywest View Post
BTW Herk, We appear to have the same units (8526 RLWS), what does yours weigh when loaded up ? I guess the only thing I might have additional from stock is 4 batteries, a solar panel, transfer switch and inverter.
I typically run at about 9000 pounds for long trips.
The GVWR of my camper is 9169
The available payload is very low IMO, but it is what it is.
We only have 2 batteries, but since they weigh about 75 pounds each 4 should even out to a couple of cases of wine.
We left for Goshen and our junket to Mississippi and then San Diego (where we are now) weighing 9300 pounds due to two cases of homemade wine, a case of Limoncello, and an extra electric stabilizer unit for OC.
That was only for the first 2 days of a 52 day trip. The wine and Limóncello is almost all gone - consumed or donated and the stabilizer was left in Goshen with OC. Gonna have to buy substandard wine soon or crack into the frozen Margaritas.
HAM CALLSIGN - KC3FFW
Old 08-28-2013, 03:53 PM   #52
Windywest's Avatar
I appears we have something else in common, I usually travel with about 8 bottles of my home made wine, and a couple dozen beer. I always make either Merlot or Cabernet, and as you say it doesn't last all that long.. I've got a lot of thirsty friends. Thanks for the info.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 08-28-2013, 04:47 PM   #53
Herk7769's Avatar
Besides RVing you mean!
Old 08-28-2013, 06:35 PM   #54
Commercial Member
I went to load range E from C on the advice of the tire shop owner/manger, he said I could run them at 80 lbs, but recommended 65 due to the lighter weight of my camper approx 7200 dry. He also said he sold a lot of these tires and had never had any come back. I trust this guys advice, it's a small town, so anything negative or bad service reports get around quickly. I haven't weighed my trailer lately, but these tires are rated to carry over 2800 lbs at max inflation. Doing the math and having about 1200 in the truck box, that leave about 6000/4 or 1500 lbs per tire, dry weight, so I've got lots of spare capacity. I haven't gone all that far with them, but the 50 mile ride home seemed smooth and easy.
If you really only have 1500 per tire I do not understand why you went from C to E. While the tire store was making the sale (more expensive) did he point out that the wheels are rated for xx psi max and yyyy lbs max? Note this is based on the COLD set point inflation not hot inflation.
I bet he didn't bother as if he had he might not have made the sale of the more expensive LR-E.
BTW what size tire do you have?
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 08-28-2013, 07:35 PM   #55
Incheon, S. Korea
BigBaron's Avatar
Not having a fiver myself but always trying to learn, I would get an E tire if I could afford it. Actually, I'd get the best tire I could afford. Money well spent. I put LT tires on my pups, and plan on getting an old Spartan and rebuilding it when we move back.
Thanks for the info everybody!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 08-28-2013, 08:21 PM   #56
Windywest's Avatar
I have ST225 75 R 15s, and the load range Cs were the basic tires from the factory. After having a blowout on a busy highway, I'm not taking a chance on my family's safety with tires that won't stand the heat or load. After checking around, the load range E tires aren't that much more than Ds, and I'm not going to quibble over a few bucks. Since I was caught in a jam away from home, I bought the LR Es so I could get home. The rims are rated at 2830 lbs each at 5 / 5 1/2, I suspect they make them all the same and drill the holes after the forge so either load range D or E are acceptable for pressure, but you can't go over the GVW rating. I'm happy so far, the money is paid and I feel a lot safer. I might have a different opinion next year, but that will be next year.
Old 08-29-2013, 11:07 AM   #57
Windywest's Avatar
Tireman9, just wanted to compliment you on your site at RVtiresafety, lots of good info there, easy to read, and easy to find. I just noticed one point that you made in regards to load range and tire pressure. You mentioned that a Load range E inflated to 65 lbs can't carry anymore load than a LR D at 65, since it's the air that carries the load, the tire and rim support it. This fact makes things a lot clearer to me, and running my LR E tires at 65 psi, should make my trailer pull without a lot of bounce, and shouldn't negatively impact the safety of the tires. (my thinking anyway)
Old 09-03-2013, 09:31 AM   #58
Looking to replace all four of our tires. We have a 2011 Sandpiper fifthwheel. Need some advice on which tires to purchase. New to forum, so not sure how to go about getting some advice. Currently have LT235/85R16E and have had nothing but trouble. Any advice/help would be appreciated.
gotyacovered is offline   Reply With Quote
Old 09-03-2013, 09:49 AM   #59
Send a message via MSN to Tiggerdad
I will never use anything of that an LT tire. BFG Commercial T/A is a very popular tire on other RV forums. That is what I have and now have 20,000 + with no sign of wear. California, Arizona, Montana etc. Have been all over the country. Firestone Transforce came on my truck and also seems to be becoming increasingly popular. Many tout Duravis and Michelin XPS but IMO, they are much more tire that most people need and are very expensive.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 09-03-2013, 09:50 AM   #60
Lots of recommendations for tires- but I personally went with Maxxis m8008 after reading overwhelmingly positive reviews for people online.
My review: it's a tire and it goes round.
I bought from discounttiredirect.com and had great customer service especially once one of my tires went MIA with UPS.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
led pad
