Old 12-19-2014, 09:35 PM   #31
dcheatwood's Avatar
I use my harbor freight laser thermometer to check oil temp when frying fish or turkeys, checking air temp coming from a/c registers, etc. Plus it works on wheels too. Lol.
2018 Forester 3011 DS
Old 12-20-2014, 03:13 PM   #32
Explorer
We all talk about high temps and issues but two years ago I had a hub with lower than average temp.For three trips I was thinking “I’ve got that hub dialed in, I need to do the rest the same”. WRONG, when I did my spring check I had a broken wire on the brake magnet. No brakes, no heat, not good
Made me smile a little that I am always leaning something: high temps are bad but low temps aren’t good either.
Campers are Fun
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 12-20-2014, 03:48 PM   #33
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Checked this one on-line at Harbor Freight and it has pretty good reviews. On sale for 19.99 and there is an on-line 25% off coupon good through Dec. 21. Think I'll drive over tomorrow and get one. Thanks for the tip.
Infrared Thermometer - Non-contact, Digital Thermometer
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 12-20-2014, 04:11 PM   #34
dcheatwood's Avatar
That's not the one I have but i got it on sale at harbor freight and with a coupon. Works fine.
Old 12-20-2014, 04:23 PM   #35
dcheatwood's Avatar
I have this one. $29.99 on sale plus %25 off coupon.
Old 12-20-2014, 04:52 PM   #36
RPAspey's Avatar
There are a few things that one must realize using the laser thermometers. Because IR emissivity values are different for different surfaces, you should always take a reading at the same spot/area at each hub. Color affects the reading as does chemical makeup.
Also, the area that is "read" gets larger as you are farther away. Stay close to your target. Most IR thermometers have a scale on them somewhere showing the target to distance ratio. So stay close. You don't want to skew your readings with a cooler part getting read.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 12-20-2014, 05:20 PM   #37
dcheatwood's Avatar
Yes. And the laser is just for aiming. It doesn't actually read the temp as I understand it.
Old 12-20-2014, 08:36 PM   #38
RPAspey's Avatar
Correct. The laser only allows one to "aim" at the intended target. The shiny silvery lens located near the laser is the actual sensor. It should be kept clean using only a soft rag such as a micro-fiber cloth.
tire
