06-03-2018, 09:35 AM
Tire, axle, brakes, hardware, springs replacement.
Due to a blown tire, split in tread running 35 mph in town, about 2 years old, full 50psi. Purchased a new tire in Danville Va. Drove home, 120 miles. Inside tread worn badly on new tire. Looked at wheels and tires, measured camber, RR was 3 deg. neg, LR was 2 deg. Neg. Other axle looked fairly good. Decided to replace all 4 tires and both axles.
After starting the tear down, noticed hangers and bushings were worn. It's a 2013 SOB I purchased used in 2014. Has 3500# axles. My Cat scale weight is 6500# for complete trailer. When towing, have 750# tongue weight.
I don't know what previous owner loaded into it. It has been stripped down to the spring hangers. Photos are prior to removal.
Still trying to add photos.
06-03-2018, 09:42 AM
Photos???
I think I have it now.
06-03-2018, 09:48 AM
axle replacement
Now for the new problem. I thought that if I cut the wires going to the brakes, I could pull the break away switch to see which wire was hot to the brakes. I checked the front wires, black was hot, blk/white was not. Couldn't get any hot on rear brake wires.
I put the plug back into the switch. Hooked truck to 7 wire plug, didn't hook to ball, well because it's up on 4 jack stands. No power to either brake now. Would it help if I ground truck to trailer with a jumper wire??
06-03-2018, 10:15 AM
You should already have a ground via the Bargman connector. if you have a newer brake controller, it may not activate unless it senses a connection to the brake magnets. That may be why you are not seeing anything when you are connected to the TV. The break-away switch is just a dumb switch and has no idea what is or is not connected. FR uses wire nuts to make the connections in an area that sees plenty of moisture and road dirt. I suggest while you are working on this, you cut and reconnect the brake connections with solder or a waterproof connector.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-03-2018, 01:33 PM
Bearing size
How do you determine what is bearing size?
2011 300Rl 5th Wheel trailer.
I’d like to have bearings before pulling off.
2011 5thWheel Sierra
F250 Ford 2008 Diesel
Larry & Sharon
06-03-2018, 01:38 PM
Bearing size
I googled my axel size and followed recomendations. Some axles have multiple sizes.
06-03-2018, 04:00 PM
They sell a tool called a power probe. Hook two wires to any 12 volt battery and a clip to what you are working on to ground it. Then you can test for power, ground ,open, etc. Once you have one you find all kinds of uses. You can even power anything thats 12 volt and not have it in your unit.
06-03-2018, 05:20 PM
Your axles should have a paper tag on the back of each one with your weight rating. With that if you go to etrailer.com they have pretty good listings.
Because we do long trips sometimes in remote areas, I've taken pictures of all components and component numbers and have everything in an album on my phone. You can also pull a wheel and measure your brake drum to confirm brake sizes.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
06-03-2018, 06:11 PM
I have not seen shackles at that severe an angle. Usually they are more vertical and with no load on them now they would be closer to horizontal when set back on ground.. Makes me think you springs are to short. BUT, I am no expert and could be wrong.
Just looked at mine. They are almost vertical.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
06-03-2018, 07:32 PM
Each part of the bearing, the cone and race, should have numbers on them. Most Auto Parts stores can look up replacements from those numbers.
This is the best way in case the manufacturer pulled a switch without telling anyone.
Just pull one wheel and get numbers off inner and outer bearings. While at it get number off seal too.
06-03-2018, 07:46 PM
If you have negative on both axles doesn't that indicate a bent axle?
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
06-03-2018, 08:06 PM
You can also have that with worn out bushings. Wore the insides of 4 fairly good tires because of that. Changed them and everything back to the way they should be wear wise.
06-03-2018, 08:21 PM
Didn't know that. I don't have much experience with axles and springs on trailers.
06-04-2018, 07:57 AM
That was about 60000 miles on the trailer. Now that I know, I will check them around 30000 miles.
