Old 05-28-2013, 12:10 PM   #31
Southwestern Newbie
Misterdanderson's Avatar
Originally Posted by OldCoot View Post
Don't disagree with either the finger or cone balancing, I'm just saying that after spending 45+ yrs in manufacturing, the chances of an alum forged wheel machined on a CNC machine would not be 4 or 5 oz out of balance without it shaking the machine and being rejected. By the very nature of a forging, it is extremely unlikely to produce such a defect. Also, if the wheel is machined on a CNC, it is just about impossible to produce an out of round or wobbling wheel.
In America, I agree. Chinese (and other countries) stuff coming to our store sometimes not up to same quality standards as one would hope for. Ideally forging and CNC exact, but in the service bay that wasn't always our experience.
2006 Flagstaff M-23lb with triple bunk.
2004 Dodge Durango SLT 2wd; Yeah, it's got a Hemi.
100 watt solar kit with Trojan AGM Series 31 pending
Misterdanderson is offline   Reply With Quote
Old 05-28-2013, 12:18 PM   #32
Herk7769's Avatar
Originally Posted by maggiek View Post
Could the fact that the tires have about 3000 miles on them in the unbalanced state influence the amount of weight required the bring them into spec? Just thinking out loud and trying to justify the weight required to get the tires balanced. It just seems to be a lot considering they are built for "fair weather" use, not like they are heavy snow or all terrain tires.
Well there is another variable to consider.
HAM CALLSIGN - KC3FFW
Old 05-28-2013, 03:32 PM   #33
maggiek's Avatar
Re:tire balancing
Further to my post of yesterday. I did the bearings on the other side today, again without to much heart ache. The discussion is centered on the tire balancing. So, for the right side tires the additional weight required was. 5 oz and 2.5 oz. The machine was the same one as yesterday as was the tech. The method was with the cone mount. So for some thoughts:
1. The tt is a Rockwood Mini Lite 2304.
2. With the floor plan most of the weight is on the left side. That is stove, fridge, furnace and water heater. The right side has the shower and dinette.
3. When checking the tires/hub temps during our travels I've noticed about a 20F temp differential between the left/right sides. The left side hotter. The brakes seem to be adjusted about the same using the dirt road method for comparing the stopping effort of the tires on each side. The little piles of gravel were about the same and the skid marks were also about the same. So one could discount one set of brakes being "tighter" than the other.
So, I'm thinking the extra weight on the left side could, over time, along with the tires not being balanced from new, cause some deformity/wear pattern that is causing the excessive weight required to bring the tires into balance. Anyway, I'll know on Fri after the tt goes for its spring service. I'll let y'all know how it feels.
Steve & Millie
Maggie
2011 RAM 1500 Quad Cab 2wd Hemi 3:55 gear
Rockwood Ultra-Lite 2604WS
maggiek is offline   Reply With Quote
Old 05-28-2013, 09:20 PM   #34
amxpress's Avatar
Trailer axles are stud centric, as they center the rim using the studs. That's how the rim should be balanced; by using the fingers mounted on the outside during balancing.
As for the quality of aluminum rims, I found the post on the aluminum rims used on my Columbus and other FR products to be impressive. That being said, they still need to be balanced using the fingers.
The point of having a properly calibrated machine is important as I often find that to be a problem.
And finally, the skill of the balancer operator is very important.
I do this stuff for a living and in my 30+ years of experience have seen all these to be potential problems when balancing a tire/rim assembly.
1) crappy tires
2) cheap quality rims
3) improper mounting on the balancer
4) not having a calibrated balancer
5) a mechanic that isn't properly trained on balancing a tire.
As I've already said, have the tires balanced on a Hunter 9700 by a qualified mechanic.
I've hooked up an NVH analyzer inside a TT before and after a balancing the tires. There was 20+ Dbg less after balancing the tires, a BIG improvement in the ride quality inside the TT.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 05-28-2013, 09:40 PM   #35
1) crappy tires
You forgot a major potential problem is an improperly seated tire.
In my 40+ yrs of pulling rv trailers and having the tires balanced using a cone, I've never had cupped tires from them being out of balance. I watch them spinning them and pay particular attention to any runout also. To me, the best way of balancing was the old spinning them on the vehicle, but you had to know what you were doing and it took a lot of experience to balance them that way.
Old 05-29-2013, 08:24 AM   #36
prof_fate's Avatar
Originally Posted by BarryD0706 View Post
No passengers? Ok, but there is a lot of dishes and electronics that I don't want vibrated all to H!!
All of the smart people on this forum get theirs balanced. ;-)
OK...but those IN THE INDUSTRY - be that TT makers, sellers, tire sellers DO NOT.
So do you see an MD when your sick or get out the crystals because everyone on 'the crystal healing website' uses crystals?
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-29-2013, 08:48 AM   #37
PHS79's Avatar
The tire shop I worked for 10 ago balanced every tire that went out the door, including trailer tires. My parents 2013 Open Range 5er came from the factory with the tires balanced. And even the tilt bed equipment trailer my boss just bought last week is hanging weights in the rims, whether it was the dealer or the factory that balanced them I don't know but they are balanced. I should also add that they are LT tires and not ST tires.
I think at this point everyone has their own opinion on the subject and it kinda like beating a dead horse...
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 05-29-2013, 12:41 PM   #38
Herk7769's Avatar
Interesting that you picked a medical example. If you are diagnosed with an illness the first thing they say is "Get a second opinion."
Why? because experts do not agree on anything. MY doctor says to get them balanced, so I will (and do).
Old 05-29-2013, 12:52 PM   #39
Originally Posted by herk7769 View Post
...MY doctor says to get them balanced, so I will (and do).
X2, only took me one set of unbalanced tires to re-confirm what I already knew, BALANCE ALL TIRES that go on the highways, etc.
Old 05-29-2013, 05:58 PM   #40
and Forest River also made the xlr27hfs Hyper Lite with 3500lb axles.. the are in the industry, the seller, etc.. that did not make it RIGHT that a 27xlr should come with 3500lb axles. And in fact the started putting 4400lb axles on later.
Your comparison is kinda weak prof_fate.. No offense.
melk-man is offline   Reply With Quote
